Turn on and thaw all layers in drawing...
I'm new to the the forum...and have been searching for about an hour to find a lisp routine that will turn on and thaw all layers in a drawing. My last company had this...all you had to do was press 'A' and all the layers would come up.
Thanks in advance.
As a LISP:
(defun c:a nil (command "_.-layer" "_Thaw" "*" "_ON" "*" "") (princ))
As a Macro (for LT users):
^C^C_.-layer;_Thaw;*;_ON;*;;
Another, LISP:
(defun c:a ( / a b )
   (while (setq a (tblnext "LAYER" (null a)))
       (setq b (entget (tblobjname "LAYER" (cdr (assoc 2 a)))))
       (entmod
           (subst
               (cons 70 (boole 4 1 (cdr (assoc 70 b))))
               (assoc 70 b)
               (subst
                   (cons 62 (abs (cdr (assoc 62 b))))
                   (assoc 62 b)
                   b
Another, Visual LISP:
(defun c:a ( / a )
   (vlax-for a (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
       (vla-put-layeron a :vlax-true)
       (if (not (eq (getvar 'CLAYER) (vla-get-name a)))
           (vla-put-freeze a :vlax-false)
(vl-load-com) (princ)
