Length of NPT thread on revolved cut face
I want to change the length of an NPT thread on a face of a revolved cut NOT on a hole feature. I have a lot of things going on in this port and that is why i did not use the hole feature.
Thanks
AndyB
When you do the thread feature, there's a check box for "full length." Un-check that, and you can change the length of the threaded section, and the offset from the end. I haven't played with it too much, but I think that the offset is from whichever end of the face was closest to where you clicked when you selected the face to be threaded.
