I know that you can select similar for color, layer, line type but is there a way to select by visibility state? All of my dynamic blocks use visibility states depending on which view you want it in (i.e. plan,front or side) and in most cases differant sizes of the object. I would like to be able to change let say the size of an object in the plan view from visibility state 1/2" insert plan to visibility state 1/4" insert plan without going to each block.
