[Help] How to check if entity lay in a Viewport
Please help me, i've a problem :
How to check if entity be viewed in a Viewport ?
For Ex, how can i erase , or locked...or do sth.. all viewport that view into a Line ?
Srr for my poor English and Thanks all ^^
You would need to translate the Viewport Boundary to Modelspace coordinates using the correct transformation matrix based on the scale/twist etc of the viewport (I think gile wrote a function to calculate this matrix), then check whether your objects lie within this point set.
Found it:
http://www.theswamp.org/index.php?topic=29231.msg347755#msg347755
Thank you very much Lee :) I try it now ^^
P/s : i'm digging Theswamp and lisp..wow.. how a great data to learn and learn and learn...
You're welcome :)
TheSwamp is awesome - so many clever guys there.
As an example for you, this quickly written code will use gile's PCS2WCS function to create an LWPolyline Viewport boundary in Modelspace:
(defun c:test ( / _lwvertices _lwpoly cen ent lst vp x )
   (defun _lwvertices ( e )
       (if (setq e (member (assoc 10 e) e))
           (cons (cons (cdr (assoc 10 e)) (assoc 42 e)) (_lwvertices (cdr e)))
   (defun _lwpoly ( l )
       (entmakex
           (append
               (list
                  '(0 . "LWPOLYLINE")
                  '(100 . "AcDbEntity")
                  '(100 . "AcDbPolyline")
                   (cons 90 (length l))
                  '(70 . 1)
                  '(410 . "Model")
               (apply 'append l)
   (if (setq vp (ssget "_+.:E:S" '((0 . "VIEWPORT"))))
           (setq vp (entget (ssname vp 0)))
           (if (setq ent (cdr (assoc 340 vp)))
               (setq lst (_lwvertices (entget ent)))
               (setq cen (mapcar 'list (cdr (assoc 10 vp))
                             (list
                                 (/ (cdr (assoc 40 vp)) 2.0)
                                 (/ (cdr (assoc 41 vp)) 2.0)
                     lst (mapcar
                             (function
                                 (lambda ( a ) (cons (mapcar 'apply a cen) '(42 . 0.0)))
           (setq vp (cdr (assoc -1 vp)))
           (_lwpoly (mapcar '(lambda ( x ) (list (cons 10 (PCS2WCS (car x) vp)) (cdr x))) lst))
Thank you Lee, it gave me some new funny idea ^^
