randy3081 Posted November 11, 2011 Posted November 11, 2011 I am currently working on Civil Drafting Project Plate 1 and have run into a problem. I am finished drawing the contour lines and have begun to draw Cedar Park Drive. Problem is when I began to locate the points for the street, they were way off of the grid area where the contour intervals are. Thus, I believe this cannot be correct and I have come up with that for some reason, the drawing units must be inches instead of feet. I don't know how this could have happened since I followed the directions for the general setup. Anyway, I know that I could scale up the grid by 12, but that won't explain the reason why this occurred. Does anyone have a better explanation? Thanks for your time Quote
ReMark Posted November 11, 2011 Posted November 11, 2011 And you have UNITS set at what? If I recall correctly the student is told to use Decimal units with the precision set to hundredths' of a foot (two decimal places). Quote
randy3081 Posted November 11, 2011 Author Posted November 11, 2011 the units are set to decimal hundreths of a foot. When i measure it just says 50.00. It doesn't tell me whether they are inches or feet but im assuming they are inches now. Quote
randy3081 Posted November 11, 2011 Author Posted November 11, 2011 everything i have found online says to use archictectural units to draw in feet and inches, but i don't see why you can't draw in decimal feet and inches. Quote
ReMark Posted November 11, 2011 Posted November 11, 2011 (edited) As far as I can tell then you are doing it correctly (as per the instructions). The way PF has you set up the drawing there is no way you could input a distance using the symbol as AutoCAD would return the following: Point or option keyword required. I'm not sure many new students to AutoCAD would know the difference between expressing a distance using architectural feet/inches and decimal feet/inches. Do a quick test. Ask someone you know what the decimal equivalent of 2'-5 1/2" would be. Maybe you should post a copy of your DWG file so someone here can take a look at it. Edited November 11, 2011 by ReMark Quote
ReMark Posted November 11, 2011 Posted November 11, 2011 Have you checked out any of the images that have been posted for this particular project? Quote
