distance from polyline points to a reference line!!???
Hello to everyone! Can you please help me with a lsp program that automaticaly generate linear dimensions from the points of a polyline to a reference line, because with the classic comand (dimlinear) i can draw the dimension line each point at a time. I attached an dwg for you to understand better. Excuse my english please!
Thanks!
distance from polyline points to a reference line.dwg
Try this:
(defun c:DimTwo(/ aDoc Space pl ReFL pt pt2 ss)
 (vl-load-com)
 (setq aDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
 (setq Space
 (if (= 1 (getvar "CVPORT"))
   (vla-get-PaperSpace aDoc)
   (vla-get-ModelSpace aDoc)
 (prompt "\nSelect Polyline:")
 (if (and
(setq Pl (ssget ":E:S:L" '((0 . "LWPOLYLINE"))))
(progn (prompt "\nSelect Reference Line:")
       (setq RefL (ssget ":E:S:L" '((0 . "*LINE"))))
     (setq RefL (vlax-ename->vla-object (ssname RefL 0)))
     (foreach pt (mapcar
     'cdr
     (vl-remove-if-not
       '(lambda (x) (= (car x) 10))
       (entget (ssname pl 0))
(vla-addDimRotated
  space
  (vlax-3d-point (append pt '(0.0)))
  (vlax-3d-point
    (setq pt2 (vlax-curve-getclosestpointto RefL pt))
  (vlax-3d-point
    (mapcar (function (lambda (a b) (/ (+ a b) 2.))) pt pt2)
  1.57079633
 )(princ)
Hope this helps
It work well! Thank you very much!
You're welcome jhonnying
Glad it worked for you.
Cheers
Try this:
 (vl-load-com)
 (setq Space
 (if (and
     (foreach pt (mapcar
     'cdr
     (vl-remove-if-not
(vla-addDimRotated
  space
  (vlax-3d-point
  (vlax-3d-point
  1.57079633
 )(princ)
Hope this helps
Hello!
Can someone help me?
In Lisp, this brings me the following error message:
"Incorrect string ssget mode"
Thank you for your help!
Martin
(ssget "_:E:S:L" '((0 . "LWPOLYLINE"))));
Not sure though :unsure:
That would be my guess, since the OP's location is Austria.
Unfortunately, no. The error persists.
Error message: Select Reference Line: with error: Incorrect string ssget mode
Best regards Martin
I'd be interested to read the available SSGET modes for the Austrian acad*dev.chm
Could this be modified to also work with horizontal distances? Ie the reference line is vertical.
Cheers
Cheers
Replace 0 to 1.57079633
  (vlax-3d-point
  [b]0[/b]
 )(princ)
Best regards Martin
You "think" you may have to do the same for
(setq RefL (ssget "_:E:S:L" '((0 . "*LINE"))));
Since the error this time comes after the Polyline is selected
Cheers
uhhmmm :unsure: Yes?
:D
It works!
Thank you!
Best regards Martin
