FELIXJM Posted November 14, 2011 Posted November 14, 2011 (edited) How to change the font type and size in MSWORD? (vl-load-com) (IF (NOT TBLWORD) (PROGN (SETQ TBLWORD (STRCAT #DRV "MSWORD.OLB")) (vlax-import-type-library :tlb-filename TBLWORD :methods-prefix "VBWORDm-" :properties-prefix "VBWORDp-" :constants-prefix "VBWORDc-" ) ) ) (SETQ VBWORD (vlax-get-or-create-object "Word.Application")) (vla-put-visible VBWORD :vlax-true) (SETQ DOCS (vla-get-documents VBWORD)) (setq DOC (VBWORDm-add DOCS)) (SETQ paragraphs (VBWORDp-get-paragraphs doc)) (setq pg (VBWORDp-get-last paragraphs)) (setq range (VBWORDp-get-range pg)) (setq TEXTO1 "1a LINHA DE TEXTO\n") (setq TEXTO2 "2a LINHA DE TEXTO\n") (setq TEXTO3 "3a LINHA DE TEXTO\n") ; (VBWORDp-put-fontname "COURIER NEW") ;???????????????????????????????? (VBWORDp-put-fontsize range "20") ;????????????????????????????????????? ; (VBWORDp-put-bold range 1) (VBWORDp-put-underline range VBWORDc-wdUnderlineNone) (VBWORDm-InsertAfter range "MEMORIAL DESCRITIVO\n") (VBWORDm-InsertAfter range "\n") (VBWORDm-InsertAfter range TEXTO1) (VBWORDm-InsertAfter range TEXTO2) (VBWORDm-InsertAfter range TEXTO3) thank you. Edited November 15, 2011 by SLW210 Add code tags Quote
fixo Posted November 15, 2011 Posted November 15, 2011 Try this code (VBWORDp-put-name (VBWORDp-get-font range ) "COURIER NEW") (VBWORDp-put-size (VBWORDp-get-font range ) 18) ~'J'~ Quote
SLW210 Posted November 15, 2011 Posted November 15, 2011 I fixed your post, but next time use CODE tags not Quote. CODE POSTING GUIDELINES Quote
FELIXJM Posted November 17, 2011 Author Posted November 17, 2011 I looked all over the internet for several days and I found this tip. Thank you. Quote
