xr309 Posted November 15, 2011 Posted November 15, 2011 Is there a way to transfer all personal settings to another computer (not networked)? Settings like: everything under Tools/Options, acad.PGP, toolbars, etc... Or just literally all settings. I know I could spend a lot of time reading the manual and figuring this out, but I thought I'd try for the quick advice of the experienced! Fantasy: (?) A magical Export All Settings/Import All Settings button! Quote
ReMark Posted November 15, 2011 Posted November 15, 2011 There is no "magic button". AutoDesk hasn't designed one yet and when they do it will be available only to those on Subscription (there will also be a price increase). Don't forget such things as... Linetypes (.LIN) Hatch patterns (.PAT) Command aliases (.PGP) Tool palettes (.ATC) Customized User Interface (.CUIx) Profile (.ARG) Lisp routines (.LSP) System variable settings (see Express Tools > SYSVDLG. Saved as a .SVF file) Quote
resullins Posted November 15, 2011 Posted November 15, 2011 I would basically copy both of your support files. There's one in Program Files, Autodesk, AutoCAD XXXX, support And there's one in Documents and Setting, , AutoDesk, blah blah blah. That's where almost all of what you need is going to be located. Just make sure you're not overwriting any cool new features! Quote
resullins Posted November 15, 2011 Posted November 15, 2011 Yeah... you know, files, folders, whatever! Yes, I mean folder. Quote
ReMark Posted November 15, 2011 Posted November 15, 2011 That's what I thought but I just wanted to be sure I understood you. I'd be very careful copying over the contents of an entire folder from one version to another. Might want to do a file comparison first. Quote
mdbdesign Posted November 15, 2011 Posted November 15, 2011 What about "Migrate Custom Setting", it won't do it? Quote
xr309 Posted November 15, 2011 Author Posted November 15, 2011 Well, well, well... There is a magic button. Start/Programs/Autodesk/AutoCAD 2012 - English/Migrate Custom Settings/Export AutoCAD 2012 Settings... I like! Quote
alanjt Posted November 15, 2011 Posted November 15, 2011 I wrote this one a while back... (defun c:BackUp (/ backupFolder dir lst) ;; Alan J. Thompson (vl-load-com) (setq backupFolder "c:\\BACKUP") (vl-mkdir backupFolder) (if (findfile backupFolder) (progn (foreach file (vl-directory-files (setq dir (vl-filename-directory (findfile "acad.pgp"))) nil 0) (if (and (wcmatch (strcase file) "*CUI,*CUIX,*MNL,*MNR,*MNU,*PGP") (vl-file-copy (strcat dir "\\" file) (strcat backupfolder "\\" file)) ) (setq lst (cons file lst)) ) ) (if lst (alert (apply 'strcat (cons (strcat "The Following files have been backed up to \"" backupFolder "\"\n") (apply 'append (mapcar '(lambda (file) (list "\n" file)) (vl-sort lst '<))) ) ) ) (alert "Nothing backed up!") ) ) (alert "Invalid defined backup folder!") ) (princ) ) Quote
ReMark Posted November 15, 2011 Posted November 15, 2011 Try migrating those settings to your home computer or the new one you just bought. Quote
tomhansjungen Posted November 17, 2011 Posted November 17, 2011 Here is a tip from Autodesk USA: Use profiles to transfer settings between computers Tom Quote
drwhite Posted January 4, 2013 Posted January 4, 2013 Ran the routine. It did not backup the *cui, *cuix files, only the acad.pgp and the acad.mnl files, why not? Quote
BIGAL Posted January 5, 2013 Posted January 5, 2013 Hopefully if I remember correct done 12 pc's Check config for the support file directory that you need to copy for a stand alone p'c (ours are networked) make a copy of these directories. Config profiles save a new ARG Make a copy of ypur current CUI it will be the one known in Config files Main customization file Copy arg cui directories to new pc Start autocad on new pc Config Profile load the new arg file and make Current, close autocad. Make a copy of your desktop Autocad icon edit the properties of this icon Right mouse click under general change the / ">" to now be /p your argfilename Start autocad you may need to config files, edit main customisation menu to point to the correct directory for your cui also check your support paths (our case network drive need to be C:\autodeskstuff\) Should work ok we find this takes about 10 mins to do as we have done so many now we also have a lisp that sets up the file & printers see post below you can edit it to your settings, make sure you edit the menufileline. ; resets the paths usefull for update versions of Autocad ; by A Houston 2011 ; This sets a reference to the install path of your product ; the gets are their for info maybe other use ; use this to find other settings ;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T) (vl-load-com) ; make temp directory ;(vl-mkdir "c:\\AcadTEMP") (setq *files* (vla-get-files (vla-get-preferences (vlax-get-Acad-object)))) ; savepath ;(vla-get-AutoSavepath *files*) (vla-put-AutoSavepath *files* "C:\\AcadTemp") ; custom icons ;(vla-get-CustomIconPath *files*)) (vla-put-CustomIconPath *files* "P:\\Autodesk\\ICONS") ; custom menu ;(vla-get-Menufile *files*)) ;PUt your menu here (vla-put-Menufile *files* "C:\\Users\\mymenu2013") ; printers config ;(vla-get-PrinterConfigPath *files*) (vla-put-PrinterConfigPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles 2011") ; printers style sheet ;(vla-get-PrinterStyleSheetPath *files*) (vla-put-PrinterStyleSheetPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles") ; printer drv's ;(vla-get-PrinterDescPath *files*) (vla-put-PrinterDescPath *files* "P:\\AutoDESK\\Plotting\\Drv") ; print spooler ;(vla-get-PrintSpoolerPath *files*) (vla-put-PrintSpoolerPath *files* "C:\\AcadTemp\\") ; template path ;(vla-get-TemplateDwgPath *files*) (vla-put-TemplateDwgPath *files* "P:\\Autodesk\\c3d Templates") ; template location ;(vla-get-QnewTemplateFile *files*) (vla-put-QnewTemplateFile *files* "P:\\Autodesk\\c3d Templates\\my2013.dwt") ;make new support paths exist + new (setq paths (vla-get-SupportPath *files*)) (setq coggpaths "P:\\autodesk\\supportfiles; P:\\autodesk\\lisp; P:\\autodesk\\fonts; P:\\autodesk\\hfs fonts;" ) (setq newpath (strcat coggpaths paths)) (vla-put-SupportPath *files* newpath) ; Tempdirectory ;(vla-get-TempFilePath *files*)) (vla-put-TempFilePath *files* "C:\\AcadTemp\\") ; PlotLogFilePath = "C:\\Documents and Settings\\ah02490.COGG-AD\\local settings\\application data\\autodesk\\c3d 2011\\enu\\" (vla-put-PlotLogFilePath *files* "C:\\AcadTemp\\") ; LogFilePath = "C:\\Documents and Settings\\ah02490.COGG-AD\\local settings\\application data\\autodesk\\c3d 2011\\enu\\" (vla-put-LogFilePath *files* "C:\\AcadTemp\\") ; xref temp path ;(vla-get-TempXrefPath *files*)) (vla-put-TempXrefPath *files* "C:\\AcadTemp\\") ; end use of *files* (vlax-release-object *files*) ; exit quitely (princ "All Done") Quote
