nila_joy Posted November 18, 2011 Posted November 18, 2011 Hi all... I have a list ("BLKCIR" "BLKCIR" "BLKCIR" "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1") I want count the numbers of same block, means if I have user input "BLOCK1... and It will be ( "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1")") I wrote a routine, but surely did some mistake (defun duplc () (setq name_lis '(..........) (setq lista '()) (setq listb '()) (setq blkinput(strcase (getstring "\nPlease Enter a Block Name :- "))) (setq count 0 len (length name_lis)) (While (< count len) (setq listc (nth count name_lis)) (if (= (member blkinput listc) nil) (setq lista (append lista (list blkinput))) ) ;if (setq listb (append listb (list lista))) (setq count (1+ count)) ) ; while listb ) ; defun I am a beginner in LISP.. this is for your kind info.. Quote
Lee Mac Posted November 18, 2011 Posted November 18, 2011 Using Visual LISP: (vl-remove-if-not '(lambda ( x ) (eq "BLOCK1" x)) '("BLKCIR" "BLKCIR" "BLKCIR" "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1") ) In Vanilla: (apply 'append (mapcar '(lambda ( x ) (if (eq "BLOCK1" x) (list x))) '("BLKCIR" "BLKCIR" "BLKCIR" "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1" "BLOCK1") ) ) BTW, did you resolve your last thread? http://www.cadtutor.net/forum/showthread.php?64380-any-other-function&p=439278 Quote
ketxu Posted November 19, 2011 Posted November 19, 2011 Or maybe like : (defun count (lst / old res) (foreach item lst (if (setq old (assoc item Res)) (setq Res (subst (cons item (1+ (cdr old))) old Res)) (setq Res (append Res (list (cons item 1)))) ) )) Or : (defun count (lst / ret) (while lst (setq ret (append Ret (list (cons (car lst)(- (length lst) (length (setq lst (vl-remove (car lst) lst)))))))) ) ret ) Quote
Lee Mac Posted November 19, 2011 Posted November 19, 2011 Another few: http://lee-mac.com/uniqueduplicate.html See 'List Occurrences' function. Quote
