blue-moonstone Posted November 21, 2011 Posted November 21, 2011 Hi everyone, I am currently working on the Oleson Village from Penn Foster. I have read a few threads on this forum regarding this project and that's how I got this far. I am almost done with the project; however, my drawing isn't showing on the paper space. I tried zoom extents but nothing shows. I believe I have done my setting right but don't know what went wrong. Could someone please help me check on my drawing and setting and see what I did wrong? Thanks a million! Blocks & Layers.dwg Quote
BlackBox Posted November 21, 2011 Posted November 21, 2011 Welcome to CADTutor! I have not opened your drawing, but to clarify, you created a viewport in PaperSpace right? If not, then consider using the MVIEW command. :wink: Quote
blue-moonstone Posted November 21, 2011 Author Posted November 21, 2011 Thank you for your reply and welcoming. I just checked and I believe I did. Also tried the MVIEW command. So far, it's still not showing. Quote
BlackBox Posted November 21, 2011 Posted November 21, 2011 (edited) You're welcome. I'll try to make some time to check the drawing you've attached in the morning when I get to work. Edited November 21, 2011 by BlackBox Quote
blue-moonstone Posted November 21, 2011 Author Posted November 21, 2011 Thank you! It's no rush, so take your time. Really appreciated your help. Again, thank you. Quote
Tiger Posted November 21, 2011 Posted November 21, 2011 You have a TREE placed far far away from your main drawing. I can see it when I Zoom > Extents and then scroll out a bit further, its a green dot to the right. Remove that, then do Zoom > Extents again and you should see your drawing just fine in the Viewport. Quote
iskalipsi Posted November 21, 2011 Posted November 21, 2011 It seems that there are two trees wandering in your drawing. Try to locate those trees and delete them. Double click on your viewport and zoom/ extents. Hope this helps. Quote
Tiger Posted November 21, 2011 Posted November 21, 2011 It seems that there are two trees wandering ... Those would be Ents, get your terminology sorted Isk. Quote
blue-moonstone Posted November 21, 2011 Author Posted November 21, 2011 Ha! That explains it. Thank you guys. I'll give it a try and fix it. Glad I joined this forum. Again, thanks a million! Quote
