mick_golfer Posted November 28, 2011 Posted November 28, 2011 Hi there, I am really new to Civil so this might sound soo dumb but I really could not find the answer in Civil manual or on forums so here comes my question. I have a surface, an alignement and a profile (view). How do I display other information on my profile view than just the alignment? My road centerline is the alignement, but I need to show also where catastral boundary lines end, utilities go etc. etc - it is all on separate layers in polylines. Can anyone please help?!? Thanks a lot in advance, Mick Quote
CyberAngel Posted November 28, 2011 Posted November 28, 2011 The recommended procedure for showing utility lines in a profile is to define them as pipes. You can create a single pipe that represents (for instance) a sewer line and give it elevations at either end. Right-click on the pipe, pick "add to profile," and click on your profile view. You'll need to define a style for the pipe that shows the cross section rather than the full length. Don't worry about "sounding dumb." There is a steep learning curve for C3D, and we're all still learning. Quote
BlackBox Posted November 28, 2011 Posted November 28, 2011 Don't worry about "sounding dumb." There is a steep learning curve for C3D, and we're all still learning. Ditto here; Heck, I'll be needing some help myself, whenever my projects permit me to begin actually working with C3D. Due to our work load, I've had to cross-train on Microstation+GEOPAK because the contracts required those apps instead. Quote
mick_golfer Posted November 29, 2011 Author Posted November 29, 2011 Hi guys, thanks for tip! It works, my line is now visible in plan view. I also tried it with feature line (just drawing a short line on surface that runs perpendicular to the alignment) and it can also be shown on the profile. What's the difference between these two in my case if I only want to show stuff in the profile view? And there is my other question : how to I mark what's-what in profile view? I found Add Label -> Note feature. This works fine but i need to input manually all the descriptions (my alignment crosses, say, catastral boundary, a few times) - is there a way not to describe each crossing point manually but assingn certain label to a polyline, so that it is displayed every time the pipe (or feature line) is displayed in profile? Mick Quote
CyberAngel Posted December 2, 2011 Posted December 2, 2011 What I do is fill in a definition for the pipe. I can then define a label style that uses the definition for any given pipe as its text. That way the label is the same in each profile, and I can update it in one place if necessary. Quote
