Vismut65 Posted November 29, 2011 Posted November 29, 2011 I have problem to run several scrips from Autolisp. It only run the last script. How to do? If I choose "str_s2" and "med_pan" I want script "DUe_stativL3.scr" and "HTKM001.scr" to insert blocks, but it only insert "HTKM001.scr". (if(= ddiag 2) (progn (if (= mychoice "str_s2")(setq a "1")(setq b 0)) (if (= mychoice "str_m2")(setq a "2")(setq b 0)) (if (= mychoice "str_l2")(command "_.script" "T:\\DUE\\Dimritning\\L3\\script\\DUe_stativL3.scr")(setq b 0)) (command) (if (= mychoice "str_s3")(setq a "4")(setq b 0)) (if (= mychoice "str_m3")(setq a "5")(setq b 0)) (if (= mychoice "str_l3")(setq a "6")(setq b 0)) (if (= mypan "ej_pan")(setq c "1")(setq d 0)) (if (= mypan "med_pan")(command "_.script" "T:\\DUE\\Hydraulschema\\script\\HTKM001.scr")(setq d 0)) (if (= mypan "med_ljudo")(setq c "3")(setq d 0)) (if (= mypump1 1)(setq e "1")(setq e "2")) (if (= myspider1 1)(setq e "1")(setq e "2")) (if (= myspider2 1)(setq f "1")(setq f "2")) /Dan DUe_stativL3.scr Quote
FELIXJM Posted November 29, 2011 Posted November 29, 2011 If you choose "str_s2" ==> (if (= mychoice "str_s2")(setq a "1")(setq b 0)) If I choose "str_l2" ====> (if (= mychoice "str_l2")(command "_.script" "T:\\DUE\\Dimritning\\L3\\script\\DUe_stativL3.scr ")(setq b 0)) "str_l2" run script and not "str_s2" OK. Quote
BlackBox Posted November 29, 2011 Posted November 29, 2011 SLW get's angry when you don't use in your posts... You wouldn't like him when he's angry. Quote
JohnM Posted November 29, 2011 Posted November 29, 2011 do you need to run scripts? can you get rid of the scripts and write them into the lisp code? Quote
Vismut65 Posted November 30, 2011 Author Posted November 30, 2011 Thank you JohnM. It worked without the script. Thank you other to. Quote
