Proctor Posted November 29, 2011 Posted November 29, 2011 Hello: if you are drawing a polyline....and (in looking at my pic) draw from point A to point B an then back up to point C, is there a way to merge the poly so that it only goes from point A to point B? Thanks, Proctor Quote
eldon Posted November 29, 2011 Posted November 29, 2011 One way, using Pedit, would be to Straighten between A and C and then move C down to B. Quote
ReMark Posted November 29, 2011 Posted November 29, 2011 You can get rid of the B to C segment by using the OVERKILL command found in Express Tools. I tested this (using your example) and got the following response in AutoCAD. Command: OVERKILL Select objects: Specify opposite corner: 1 found Select objects: 0 duplicate(s) deleted 1 overlapping object(s) or segment(s) deleted Quote
rkent Posted November 29, 2011 Posted November 29, 2011 1) explode and erase B-C, convert back to pline if necessary 2) Pick on the polyline, select the grip at C and stretch it away from the A-B pline. Then use Trim, enter, enter, pick on B-C polyline. 3) see other responses Quote
Proctor Posted November 29, 2011 Author Posted November 29, 2011 thank you all for your responses. all work great....the overkill is very quick and great to know about. Thanks again, Proctor Quote
Mike_Taylor Posted November 29, 2011 Posted November 29, 2011 Easiest way to do it would be select the polyline and simply move the grip on Point B onto the grip on Point A or C. Quote
ReMark Posted November 29, 2011 Posted November 29, 2011 Easiest way to do it would be select the polyline and simply move the grip on Point B onto the grip on Point A or C. Works good for one instance but if you had a drawing full of these abnormalities OVERKILL would do the job quicker. Quote
Proctor Posted November 29, 2011 Author Posted November 29, 2011 Both good points...thank you. proctor Quote
rkent Posted November 29, 2011 Posted November 29, 2011 Easiest way to do it would be select the polyline and simply move the grip on Point B onto the grip on Point A or C. You will leave a zero length line segment so I would recommend not doing this. Quote
Dadgad Posted December 1, 2011 Posted December 1, 2011 Overkill is great, also very helpful deleting duplicated 3Dmodels in large assemblies. I use it after exploding SOLPROF generated blocks, and it instantly deletes huge numbers of redundant lines, and cleans up just about everything else. Quote
Proctor Posted December 1, 2011 Author Posted December 1, 2011 Thank you for your input...I think I'll be using overkill alot to help me with my application. Proctor Quote
