quangducnguyen Posted July 2, 2006 Posted July 2, 2006 Hi, I've just started learning VBA in CAD.I wanna select polyline onscreen and then get its coordinate(of every vertex).But I don't know how to do it. Thanks for any help. Bye Quote
Steven Bastiaanse Posted July 6, 2006 Posted July 6, 2006 Something like this? Sub Example_Coordinates() Dim Selection As AcadSelectionSet Dim Poly As AcadLWPolyline Dim Obj As AcadEntity Dim Bound As Double 'Makes a selectionset. 'On Error Resume Next Set Selection = ThisDrawing.SelectionSets.Item("Select polyline.") If Err Then Set Selection = ThisDrawing.SelectionSets.Add("Select polyline.") Err.Clear Else Selection.Clear End If 'Select the polyline. Selection.SelectOnScreen For Each Obj In Selection If Obj.ObjectName = "AcDbPolyline" Then Set Poly = Obj On Error Resume Next Bound = UBound(Poly.Coordinates) x = 0 y = 1 For i = 0 To Bound / 2 MsgBox "X= " & Poly.Coordinates(x) & " Y= " & Poly.Coordinates(y) If Err Then Err.Clear x = x + 2 y = y + 2 Next End If Next Obj End Sub I hope this helps you! Greetings Quote
vitaminm Posted June 2, 2012 Posted June 2, 2012 Hello, someone please, Sub Example_Coordinates() without the sub xx() how to run this code? Quote
fixo Posted June 3, 2012 Posted June 3, 2012 (edited) Hello, someone please, Sub Example_Coordinates() without the sub xx() how to run this code? Try another one instead,type vbarun in the command line, select "demo" sub Option Explicit Function PolyCoords(oEnt As AcadEntity) As Variant Dim cnt As Integer Dim i As Integer Dim j As Integer Dim iStep As Integer Dim varPt As Variant Dim dblCoords() As Double Dim dblVert() As Double If TypeOf oEnt Is AcadLWPolyline Then iStep = 2 ElseIf TypeOf oEnt Is Acad3DPolyline Or _ TypeOf oEnt Is AcadPolyline Then iStep = 3 End If dblCoords = oEnt.Coordinates ReDim ptsArr(0 To (UBound(dblCoords) + 1) \ iStep - 1, 0 To iStep - 1) As Double For i = 0 To (UBound(dblCoords) + 1) \ iStep - 1 For j = 0 To iStep - 1 ptsArr(i, j) = dblCoords(cnt) Debug.Print ptsArr(i, j) cnt = cnt + 1 Next Next PolyCoords = ptsArr End Function Sub demo() Dim pts As Variant Dim varPt As Variant Dim oEnt As AcadEntity ThisDrawing.Utility.GetEntity oEnt, varPt, vbCr & "Select polyline" If Not TypeOf oEnt Is AcadLWPolyline And _ Not TypeOf oEnt Is Acad3DPolyline And _ Not TypeOf oEnt Is AcadPolyline Then MsgBox "Method is not applicable for this entity type" Exit Sub End If pts = PolyCoords(oEnt) End Sub Next tyme post your question on VBA branch, please: http://www.cadtutor.net/forum/forumdisplay.php?69-.NET-ObjectARX-amp-VBA ~'J'~ Edited June 3, 2012 by fixo Quote
vitaminm Posted June 6, 2012 Posted June 6, 2012 Try to change ( by ( and ) by ) in code Ya, tq, it woks now! Quote
Karma Posted February 8, 2013 Posted February 8, 2013 I’m a bit discouraged, I started to learn acad-vba since a few days too & I wanted to understand Steven Bastiaanse’s example which seems simple. Why #40 & #41 , what does it mean. Set Selection = ThisDrawing.SelectionSets.Item (”Select polyline” & #41; ??? (ThisDrawing.selectionsets) expected object or method isn’t it? Thanks for helping me Quote
imagination_s Posted October 30, 2014 Posted October 30, 2014 Hello Sir Please hlep me with this I need to add a polyline based of part of coodonates of first polyline So i need to copy vertex example from 0 to 5 of first polyline. Thnakyou Quote
BIGAL Posted October 31, 2014 Posted October 31, 2014 Here is a VL example you will end up with a variable co-ordsxy which contains all the pts for a 2d pline as 2 values (x1 y1 x2 y2 x3 y3..... you can then get each pair from the list using nth x & nth (+ x 1) ; pline co-ords example ; By Alan H (defun getcoords (ent) (vlax-safearray->list (vlax-variant-value (vlax-get-property (vlax-ename->vla-object ent) "Coordinates" ) ) ) ) (defun co-ords2xy () ; convert now to a list of xy as co-ords are x y x y x y if 3d x y z x y z (setq len (length co-ords)) (setq numb (/ len 2)) ; even and odd check required (setq I 0) (repeat numb (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords) )) ; odd (setq xy (list (nth i co-ords)(nth (+ I 1) co-ords)(nth (+ I 2) co-ords) )) (setq co-ordsxy (cons xy co-ordsxy)) (setq I (+ I 2)) ) ) ; program starts here (setq co-ords (getcoords (car (entsel "\nplease pick pline")))) (co-ords2xy) ; list of 2d points making pline Quote
imagination_s Posted October 31, 2014 Posted October 31, 2014 Please do not get upset for me asking. Is there a way to do this in vba macro for autocad not lisp? Thankyou very much. Quote
BIGAL Posted October 31, 2014 Posted October 31, 2014 Fixo's code above Debug.Print ptsArr(i, j) will contain the points. So something like x= ptsArr(i) y=ptsArr(j) I am sure Fixo will confirm. Quote
