Hello Brain trust,
I hope yu guys are firing on all cylinders today.
I am getting some drawings ready to go out to the clint. They only want one style of text in their deliverables.
I have a some drawings that have a secondary text style. I have tried to purge it out, it won't go. Flat refuses!
I tried:
  1. SSX, Entity, text and mtext. adding Style, simplex. found 0 doing that
  2. I tried using the quick select box to find it. 0's
  3. I tried turning on all and unlocking all layers, then reapeating the previose 2 steps. 0's
  4. I quick selected all my blocks and manually checked them one at a time. 0's
That's my whole bag of tricks for this kind of thing!!!!!!
Can any one else think of a way to find this stupid text style?
have you made sure its not the current textsyle in the dwg?
No. I hadn't thought of that one. But unfortunately it wasn't and it still wont purge.
I do seem to be banging my head against a wall to a Christmas kind of beat though. " I'm singing deck the halls. . . ."
Post the drawing. Someone will figure it out.
Wish I could remark but, they were suppose to lock these drawings in a drawer even when we go to the can.
Iv'e ended up copying all the drawings and creating a new drawing. What a pain but, the bad text styl didn't travel. Near as I can figur it was blank mtext box somewhere.
Next time use -PURGE (notice - in front) and purge Empty text objects.
You can also check for empty text boxes turning QTEXT on. It will display boxes instead of text and you can see if there are any stray ones lying around.
When I clean up drawings, it's very common that the text style that you can't purge is embedded in a block in that drawing. Even if the block doesn't actually have 'text' it in, it might have been part of the block when it was originally created. I can sympathize, it's a complete PITA to hunt down and find.
I used to get really annoyed when trying to purge "phantom" layers, until I started using LAYMRG, which gets them every time. By using the "name" option, you don't need to find the troublesome bits and select them.
works great,as long as the problem isn't in one of your blocks.
Thanks guys! You added a few more grenades to my bag of tricks.
Happy BEER:30 to all (much like 5:30 only with beer) and to all have a good FRIDAY .
A bit extreme isn't it?
