Amps Posted December 2, 2011 Share Posted December 2, 2011 I'm trying to create a dynamic block with visibility states for different wireframe sections, with objects (simple lines) in x,y & z planes. The block represents a bay of scaffolding, which dynamically arrays in length in set bay sizes, but i want to add visibility for different height section arrangements (i.e number of scaffold lifts in 2m lift heights) I have this working with the maximum section (16m high), and I hoped to be able set visibility states from for the sections 16m down to 6m by "make invisble" the upper scaffold lifts in reducing heights. The block editor will only give me the plan (x,y) view to modify the dynamic elements. Is there a way to view left, right or even isometric in the block editor?? Any help appreciated. Howard Quote Link to comment Share on other sites More sharing options...
SLW210 Posted December 2, 2011 Share Posted December 2, 2011 No 3D for dynamic blocks. You will need to make seperate blocks. Quote Link to comment Share on other sites More sharing options...
