Hi,
I have a problem with action tile. I want to change contents in a popup_list when I push different radio buttons. I have write the code:
(action_tile "str_l2"
    "(start_list \"mylist1\" 3)
    (mapcar 'add_list myList5)
    (end_list)"
 (action_tile "str_l3"
    (mapcar 'add_list myList6)
    (end_list)"
But it doesnt work
/Dan
Welcome to the forum Dan
Radio button return value would be "1" or "0"
(if (eq radiobuttonval  "1")
(start_list "mylist1")(mapcar 'add_list myList5)(end_list);<---- pointing to the same key but different lists
(start_list "mylist1")(mapcar 'add_list myList6)(end_list);<-----
Hi Dan,
After a quick look at your code, it looks like it should work.
I would suggest creating a subfunction to populate the DCL popup_list tiles:
(defun FillPopupList ( key lst )
   (start_list key)
   (foreach item lst (add_list item))
   (end_list)
(action_tile "radio_button_key1" "(FillPopupList \"popup_list_key\" YourList1)")
(action_tile "radio_button_key2" "(FillPopupList \"popup_list_key\" YourList2)")
Hi,
Thank you for the answer, but I have 6 radio buttons. How to do with 6 buttons.
I have an another problem also.
I have 2 pop_ut lists. I want the second pop_up list to be grey_out. But when I have make a choose in the first pop_up list I want the second pop_up list be activated.
Very quick example:
DCL code (save as "test.dcl"):
test : dialog { label = "Example"; spacer;
   : boxed_radio_row { label = "Select List";
       : radio_button { key = "radio1"; label = "List 1"; }
       : radio_button { key = "radio2"; label = "List 2"; }
   spacer; : popup_list { key = "popup"; } spacer;
   ok_only;
LISP code:
(defun c:test ( / FillPopupList lst1 lst2 id )
   (setq lst1 '("One" "Two" "Three" "Four")
         lst2 '("Red" "Yellow" "Green" "Blue")
       (start_list key)
       (end_list)
   (cond
       (   (<= (setq id (load_dialog "test.dcl")) 0)
           (princ "\ntest.dcl file not found.")
       (   (not (new_dialog "test" id))
           (princ "\nDialog could not be loaded.")
       (   t
           (FillPopupList "popup" lst1)
           (set_tile "radio1" "1")
           (action_tile "radio1" "(FillPopupList \"popup\" lst1)")
           (action_tile "radio2" "(FillPopupList \"popup\" lst2)")
           (start_dialog)
   (if (< 0 id) (unload_dialog id))
Hi Lee Mac,
That worked great. Thank you.
I have one more issue. I have 2 pop-up lists The first(mylist20) is set to "true" and the second(mylist21) is "false"(greyout). That I want to do is when I have make my choose in the first pop_up I want the second to be activated ("true"). I filled in some in your defun FillPopupList but it doesnt work. Do you know how to do?.
   (start_list key)
   (end_list)
      "(mode_tile \"mylist21\" 0)"
Perhaps this example will indicate how to enable / disable tiles within action_tile expressions:
   spacer;
   : popup_list { key = "popup1"; }
   : popup_list { key = "popup2"; }
   spacer;
   ok_only;
LISP code:
       (start_list key)
       (end_list)
   (cond
       (   t
           (FillPopupList "popup1" lst1)
           (FillPopupList "popup2" lst2)
           (mode_tile "popup2" 1)
           (action_tile "radio1" "(mode_tile \"popup1\" 0) (mode_tile \"popup2\" 1)")
           (action_tile "radio2" "(mode_tile \"popup2\" 0) (mode_tile \"popup1\" 1)")
           (start_dialog)
Very quick example:....
Quick mind, quick programming....
Hello Lee Mac,
Sorry for the late answer, have been on a business tripp.
I have one more issue. I have 2 pop-up lists the first "Select el.motor" (mylist20) is set to "true" and the second "Select pump"(mylist21) is "false"(greyout). That I want to do is when I have make my choose in the first pop_up I want the second to be activated ("true"). Do you know how to do?.
dimdialog5 : dialog { // Första
label = "Dimention drawing";
: row {
: boxed_radio_column {
: row {  // Row 1
: boxed_radio_column { // Boxed_radio_column 1
 label = "Size Cabinet";
  key = "size";
 : radio_button {         // defines the Lightweight radio button
  label = "&Small 2D";
  key = "str_s2";
 // value = "1";
 : radio_button {         // defines the old-style polyline radio button
  label = "&Medium 2D";
  key = "str_m2";
  label = "&Large 2D";
  key = "str_l2";
  label = "&Small 3D";
  key = "str_s3";
  label = "&Medium 3D";
  key = "str_m3";
  label = "&Large 3D";
  key = "str_l3";
             }// Boxed_radio_column 1
: boxed_radio_column { // Boxed_radio_column 2
               : boxed_radio_row {
                 label = "Parts";
                key = "S2pop";
          value = "0";
               is_enabled = true;
 : popup_list {
               key = "mylist20";
               label = "&Select el.motor";
               fixed_width_font = true;
               width = 30;
               value = "";
         is_enabled = true;
 : popup_list {
               key = "mylist21";
               label = "&Select pump";
               width = 30;
               value = "";
         is_enabled = false;
              : popup_list {
               key = "mylist7";
               label = "&Select cooler";
               width = 30;
               value = "";
        is_enabled = true;
             : boxed_radio_row {
               key = "m2pop";
        value = "0";
               is_enabled = false;
: boxed_radio_row {
: row {
 label = "Panels";
 label = "Panel";      // defines the radio button areas
          key = "panel";
 : radio_button {         // defines the ActiveX radio button
  label = "&Inga paneler";
  key = "ej_pan";
  label = "Med paneler";
  key = "med_pan";
  value = "1";
 : radio_button {         // defines the (entmake) radio button
  label = "Med paneler+ljudoption";
  key = "med_ljudo";
 : column {
  label = "&Singelpump";
  key = "sp";
  value = "1";
  label = "Tandempump";
  key = "tp";
: row {
 label = "Spider";
: column {        // defines the radio button areas
  label = "&Ingen spider";
  key = "i_spid";
  value = "0";
  label = "&Placering höger sida";
  key = "phs";
  value = "1";
  label = "&Placering vänster sida";
  key = "pvs";
 : column {
  label = "&Panel utsida dörr";
  value = "1";
  key = "pud";
  label = "&Panel insida dörr";
  key = "pid";
               : boxed_radio_row {
               label = "&Replenishment";
 : popup_list {
               key = "rep";
               label = "&Välj";
               width = 30;
               value = "";
         //is_enabled = false;
: boxed_row {
             : button {
               key = "accept";
               label = " Okay ";
               is_default = true;
             : button {
               key = "cancel";
               label = " Cancel ";
               is_default = false;
               is_cancel = true;
} //Sista
/Dan
You can include a mode_tile statement within the action_tile statement of the first popup_list.
However, a popup_list will always have a selection (even before the user has chosen something an item will be shown), so the behaviour you are looking to achieve may not be intuitive for the user.
Lee
Tanks Lee for your anwer,
I have one more issue. I want to have different contents in two popup_lists "mylist20" and "mylist21" depending of chooise "sp" or "tp". I have wrote a code see below but it doesnt work. Can you help me?.
(action_tile "sp"
 (action_tile "str_s2" "(FillPopupList1 \"mylist20\" mylist1)(FillPopupList2 \"mylist21\" mylist70)")
 (action_tile "str_m2" "(FillPopupList1 \"mylist20\" mylist2)(FillPopupList2 \"mylist21\" mylist71)")
 (action_tile "str_l2" "(FillPopupList1 \"mylist20\" mylist3)(FillPopupList2 \"mylist21\" mylist72)")
 (action_tile "str_s3" "(FillPopupList1 \"mylist20\" mylist4)(FillPopupList2 \"mylist21\" mylist73)")
 (action_tile "str_m3" "(FillPopupList1 \"mylist20\" mylist5)(FillPopupList2 \"mylist21\" mylist74)")
 (action_tile "str_l3" "(FillPopupList1 \"mylist20\" mylist6)(FillPopupList2 \"mylist21\" mylist75)")
(action_tile "tp"
 (action_tile "str_s2" "(FillPopupList1 \"mylist20\" mylist6)(FillPopupList2 \"mylist21\" mylist76)")
 (action_tile "str_m2" "(FillPopupList1 \"mylist20\" mylist7)(FillPopupList2 \"mylist21\" mylist77)")
 (action_tile "str_l2" "(FillPopupList1 \"mylist20\" mylist8)(FillPopupList2 \"mylist21\" mylist78)")
 (action_tile "str_s3" "(FillPopupList1 \"mylist20\" mylist9)(FillPopupList2 \"mylist21\" mylist79)")
 (action_tile "str_m3" "(FillPopupList1 \"mylist20\" mylist10)(FillPopupList2 \"mylist21\" mylist80)")
 (action_tile "str_l3" "(FillPopupList1 \"mylist20\" mylist11)(FillPopupList2 \"mylist21\" mylist81)")
/Dan
action_tile expressions should be strings, but you are nesting action_tile statements within action_tile statements...
