venkatesan Posted December 3, 2011 Share Posted December 3, 2011 i am going to calculate the cost estimation for civil engineering process.so i have to retrieve the data from autocad or 3d max images.how can i retrieve the data from 3d images.can you tell me the c# code ? Quote Link to comment Share on other sites More sharing options...
SEANT Posted December 3, 2011 Share Posted December 3, 2011 You will have to give a better description to the problem. Perhaps post some sample data. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 3, 2011 Share Posted December 3, 2011 What kind of data? Volumes? Quote Link to comment Share on other sites More sharing options...
venkatesan Posted December 5, 2011 Author Share Posted December 5, 2011 i have to retrieve the data like( line coordinates,size of the line as text format mentioned on the line,no of beams,total area,angles,interior designs...etc...) Quote Link to comment Share on other sites More sharing options...
Organic Posted December 5, 2011 Share Posted December 5, 2011 Insert the image, scale it so that it is too real world scale, then draw polylines over your beams etc to find the (approx.) beam lengths. No C code required. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted December 5, 2011 Share Posted December 5, 2011 I think there is some confusion about the type of data you have to start with (images? - that is usually used to refer to digital pictures of the type jpg, bmp, png) 3d? that is a model. Attach an example file here that you are trying to retrieve data from. (I don't think you will get much from 3d Max files.) Quote Link to comment Share on other sites More sharing options...
