I need to extract points from an Autocad Drawing and give them the same point numbers as shown on the drawing. Can anyone help? The drawing is a foundation plan showing pile foundations each with its unique number. I would normally draw a point over each pile and then copy and paste in preparation for uploading to my survey kit but it would be good to keep the same ref point. I suspect it may be a complicated process but any advice welcome. :? (I'm using a 2008 version)
Looks like we can eliminate the use of a lisp routine since you are using the LT version.
I am a bit unsure as to exactly what you copy and paste. I suspect that it is the coordinates.
You are extremely hampered in using LT. I don't know whether you have any data extraction built in. :unsure:
Whilst I cannot give you hope for the automation of the process, you could draw a polyline between the points, in the order of the point numbers. Then list the polyline, and you can copy and paste more coordinates at a time. :D
I don't think one can do a data extraction to a table but one could extract attributes to a text file in LT 2008.
As the OP seems to be in my vicinity, perhaps I should start up a data extraction service :D
Civil 3D (or pretty much any other civil or survey package) can do this.
If LT supports Fields in a block then make the attributes the insertion point plus a pt number then like Remark extract attributes to a file, you would manually have to enter number,
Else ID copy and paste to say excel create a csv using excel
