Well, first of all great forum to all the people that like and enjoy Autocad.
This is my first post and I start with a question :D
How can I rotate an object and make a copy every time I click on a different angle.
Ex. I rotate a line and every time it makes a copy, so the final object will be like a star * (if I make me understandable)
I know is too easy but I just can remember how to do it.
Thanks to all
  • Replies 21
  • nocturne00
    4
  • warlock
    3
  • SAFeSTeR
    3
  • bonehead411
    2
You can use the COPY option under rotate,
Rotate
Specify rotation angle or [Copy/Reference] :
Rotate can be a little limited coz it doesnt have a rotate,copy, multiple option.
I think a better way to achieve a multiple rotation copy is to use the ARRAY command using the Polar Array option. Explore it, its a lot better than copy rotating it one by one
:D ow and welcome the the forum by the way:D
stick around, lots and lots of things to learn
Thanks,
But I know that there’s a way to keep making copies while you rotate the object and click in different angles...
Don't you know any other option without using Array??
Thank you.
Select the object/s you want to rotate. Click on a grip, if ther'es one on your rotation base point choose that one, if not nevermind, you can choose a base point later. Hit enter twice to cycle through the grip options to the rotate option. (At this juncture, if you need a different base point press 'B' > 'Enter' > specify base point, then) Press 'C' > 'Enter' > specify rotation angle. This will keep copying until you exit the command.
:shock:
That's what I was talking about.
Cheers mate
nice, never thought a rotation option would come out after hitting enter twice. I feel a tip of the day for this one
Cheers
Pleased I could help, I use this one a lot.
Tip of the Day? How cool would that be for my 11th post?! :D
  • 7 years later...
Thank you very much. That helped a lot !!!
does it worl with 2010? coudnt do it
I just performed it on my station. Using ACAD 2014 here.
  • 2 weeks later...
What about mirror, don't erase original? Maybe I'm not fully understanding the desired result, but to rotate from a basepoint and keep the original object I've used mirror with great success.
posted in 2008?
you need a lisp program!
posted in 2008?
Why? Are the other solutions not working for you?
  • 3 weeks later...
I use 2016 and I don't seem to have this grip rotate feature, it would be handy as I do a lot of grip editing in my work.
I saw that different grip options appear depending on the type of object I select (then hover over a grip), for example, a polyline will show 'stretch vertex' or 'add vertex' while a standard line will show 'stretch' and 'lengthen', when I choose an option there isn't an option to rotate.
Post #6? [10 chars]
Select the object/s you want to rotate. Click on a grip...
Hit enter twice to cycle through the grip options to the rotate option...
You have to click the grip, not just hover over it. You can also just right-click and select an option, the right-click options can be changed in the CUI.
I know, I also mentioned that when I actually choose an option from the grip menu that the rotate option isn't available.
Nothing seems to work so I'll leave it at that.
