Hello all,
I'm pretty new to the reactor side of coding and I'm trying to make one that does a regenall after doing a grip_stretch to a polyline on a specific layer "a-area". This is what I've found so far. Thanks
(if (not *field-update*)
(setq *field-update*
(vlr-command-reactor "Field-Update" '((:vlr-commandended . field-regen)))
(defun field-regen ( reactor params )
(cond
( (equal params '("GRIP_STRETCH"))
(vla-regen
(setq *acdoc*
(cond ( *acdoc* )
( (vla-get-activedocument (vlax-get-acad-object)) )
acactiveviewport
Here is a quick example for LWPolylines:
(vl-load-com)
(if (null *grip-reactor*)
   (setq *grip-reactor*
       (vlr-command-reactor "grip-reactor"
               (:vlr-commandwillstart . grip-reactor-start)
               (:vlr-commandended     . grip-reactor-end)
               (:vlr-commandfailed    . grip-reactor-fail)
               (:vlr-commandcancelled . grip-reactor-fail)
(defun grip-reactor-start ( reactor params / en in ss )
   (if
       (and
           (wcmatch (strcase (car params)) "*GRIP_STRETCH")
           (setq ss (cadr (ssgetfirst)))
           (setq in -1)
           (while
               (and
                   (null *willregen*)
                   (setq en (ssname ss (setq in (1+ in))))
               (setq *willregen*
                   (and
                       (eq "LWPOLYLINE" (cdr (assoc 0 (setq en (entget en)))))
                       (eq "A-AREA" (strcase (cdr (assoc 8 en))))
(defun grip-reactor-end ( reactor params )
   (if
       (and
           *willregen*
           (vla-regen
               (setq *acdoc*
                   (cond
                       (*acdoc*)
                       ((vla-get-activedocument (vlax-get-acad-object)))
               acactiveviewport
           (setq *willregen* nil)
(defun grip-reactor-fail ( reactor params )
   (if *willregen*
Out of curiosity, why do you need to regen if you grip edit LWPolylines on a particular layer?
We have a Room Tag Block w/ a square footage field linked to a polyline. So everytime we remodel a area and update are databases we modify that pline and if you do a regen it updates that field. So instead of regen everytime we do a grip_stretch it will only react we modifing a pline on a that layer. I hope that make sence. Thanks
Clear as mud. Fantastic idea.
Hey Lee, This seems to work. Thanks for your help. Now I just need to digest it. Thanks
Good stuff, shout if you have questions :thumbsup:
