Hi guys,
Looking for a way to remove the leader of the dimordinate command.
Need to label a lot of RL's with just the text vertically under the point.
Thx.
Create a Dimstyle
Suppress the following:
Ext Line 1
Ext Line 2
Arrowheads-> None
Might be ....:)
(defun c:TesT (/		 selectionset	   integer
       selectionsetname	 elist		   newselectionset
       number		 newselectionsetname
;;; Tharwat 15. Dec. 2011 ;;;
 (if (setq selectionset (ssget "_:L" '((0 . "DIMENSION"))))
   (repeat (setq integer (sslength selectionset))
     (setq selectionsetname
     (ssname selectionset
	     (setq integer (1- integer))
     (if
(member
  (cdr
    (assoc 100 (setq elist (reverse (entget selectionsetname))))
  '("AcDbOrdinateDimension")
   (command "_.explode" selectionsetname)
   (setq newselectionset (ssget "_P"))
   (repeat (setq number (sslength newselectionset))
     (setq newselectionsetname
	    (ssname newselectionset
		    (setq number (1- number))
     (if
       (eq (cdr (assoc 0 (entget newselectionsetname))) "LINE")
	(entdel newselectionsetname)
Thanks Tharwat works nicely.. would like to display the y ordinate vertically, by default it is horizontal. Maybe need to reverse the x and y.
You're welcome Dormant . :)
I think the Y coordinates are being vertically located and not horizontally , and do you want to rotate the texts to be horizontally or what ? I did not get your point well ?
Tharwat
IMO, exploding a dimension is not good practice. I would rather invoke a dimension overrides for extension lines and arrows
Just my 2 cents ;)
Exploding dimordinates would show them as mtexts only, which is not as bad as exploding linear or aligned dimensions . Although that I agree with you entirely .
If you mean to replace the selected dimordinates with another style without lines and arrows that would be a very great idea indeed .:thumbsup:
Thanks
Ive attached what i had to do. Add a RL level for every 10m over 6km.
The person before me has made individual text boxs, would of taken them weeks.
I added the "FMG Survey Points" surpressing extensions etc, worked well.
Tharwat, my y ordinate is displaying horiziontally, would like vertically. But ive finished the task now.
OLC_Profile.dwg
Try this q&d code
Change it to suit
(defun C:dor(/ *error*  acsp actsp adoc hgt ip ord osm tgap tp)
(or (vl-load-com))
 (defun *error*  (msg)
   (if adoc (vla-endundomark adoc))
   (cond ((not msg))
         ((member msg '("Function cancelled" "quit / exit abort")
         ((princ (strcat "\n** Error: " msg " ** ")
  (if osm  (setvar 'osmode osm))
;;main part
(setq adoc  (vla-get-activedocument (vlax-get-acad-object))
     actsp (vla-get-activespace adoc)
(if (zerop actsp)
 (setq acsp (vla-get-paperspace adoc))
 (setq acsp (vla-get-modelspace adoc))
(vla-startundomark adoc)
(setq osm  (getvar 'osmode))
(setq hgt 1.0)      ;<-- change leader length here
(while (and (setvar 'osmode 513)        ; <-- change point snap mode to your suit
           (setq ip (getpoint "\nSpecify Ordinate Insertion Point (or press Enter to Exit): "))
 (setq ord (vla-adddimordinate
             acsp
             (vlax-3d-point (trans ip 1 0))
             (vlax-3d-point (trans (mapcar '+ (list 0 hgt) ip) 1 0))
             :vlax-false
 ;; calculate exact value of the text gap accordingly to measurement value:
 (setq tgap (* (strlen (rtos (vla-get-measurement ord) 2 (getvar 'dimdec))) (/ (getvar 'dimtxt) 2)))
 (setq tp (vlax-3d-point (trans (mapcar '+ (list 0 (+ hgt tgap)) ip) 1 0)))
 (vla-put-textposition ord tp)
 (vla-put-textrotation ord 1.5708)
 (vla-put-textcolor ord 1)      ;<-- change text color here
 (vla-put-verticaltextposition ord 0)
 (vla-put-extlinefixedlensuppress ord :vlax-false)
 (vla-put-extlinefixedlen ord hgt)      ;<-- change leader length here
 (vla-put-arrowheadsize ord 0.0)
 (vla-put-extensionlineoffset ord 0.0)
 (vla-put-extensionlinecolor ord 4)      ;<-- change leader color here
(*error* nil)
(prompt "\n\t***\tStart command with DOR\t***\n")
(prin1)
I guess the end justifies the means. :surrender:
