how i can get the value of attribute when it is embedded into a block with multiple attributes? i am trying to get the value thru autolisp function...
This routine would extract all value form the selected attributed block to the command line ...
(defun c:TesT (/ ss n e x)
 ;; Tharwat 15. Dec. 2011 ;;
 (while
   (setq ss (ssget "_+.:S" '((0 . "INSERT") (66 . 1))))
    (setq n (entnext (ssname ss 0)))
    (while
      (not
        (eq (cdr (assoc 0 (setq e (entget n))))
            "SEQEND"
       (if (not (eq (cdr (assoc 1 e)) nil))
         (print (cdr (assoc 1 e)))
       (setq n (entnext n))
This is what i expected. Simple and easy program for beginners.
Thank you Mr.Tharwat. :)
 (while
    (while
      (not
            "SEQEND"
Excellent , You're welcome P Raja :)
Thank you Mr.Lee. i am beginner in Autolisp..I am not familiar with Visual lisp yet. However, i like your programms in these forums. They will be really helpful for me.
You're welcome Raja :) FWIW, I offer some Vanilla AutoLISP solutions further down the page.
