jamesfui
lsp help for loading & unloading arx file from specified folder!
jamesfui
hi.. need help on creating lsp that can:
> load & unload *.arx file which is located on specified folder!
example;
[size=2](defun c:arxload()[/size]
[size=2](command "load" "[/size][size=2]c:\documents & settings\user\addons\mditab17.arx[/size][size=2]")(princ))[/size]
[size=2](defun c:arxunload()[/size]
[size=2](command "unload" "[/size][size=2]c:\documents & settings\user\addons\mditab17.arx[/size][size=2]")(princ))[/size]
thanks 8)
Edited by SLW210
Share this post
Link to post
Lee Mac
Use the arxload / arxunload functions, e.g.:
(arxload "C:/YourFolder/YourFile.arx" nil)
(arxunload "YourFile" nil)
Share this post
Link to post
BlackBox
Welcome to CADTutor!
First, I'd suggest that you NOT define custom commands using the same name as that of a protected symbol (LISP function).
Second, give this a try:
(defun c:MDITAB  ()
 ((lambda (arxList mdi path)
    (princ
      (strcat "\rMDITAB: "
              (cond ((member mdi arxList)
                     (arxunload mdi)
                     "UNLOADED ")
                    ((arxload (strcat path mdi))
                     "LOADED ")))))
   (arx)
   "mditab17.arx"
   "c:\\documents & settings\\user\\addons\\")
 (princ))
Share this post
Link to post
jamesfui
wow!!! :shock:
i can't believe that it is you (Lee Mac) who is the first one to reply my first post!!! :D it sure is my pleasure!!
i was so happy, cz i'm currently using your created lsp to help on my drafting work... and it really is very very handy/useful!
that save time & effort too.... thks a lot
Actually i got plenty of issue(post) on autolisp since i started it when i feel the power lsp routines can do so much for me in autocad.
that's why i join this forum just today to seek more understanding/experience on autolisp!
Will sure try it out asap when i go back to office! 8) thanks again!!!! hAPPy
Share this post
Link to post
jamesfui
thanks for the welcome!
Feel really great to get another suggestion from you! :lol:
i'm new to autolisp but it sure gives me the interest to learn deeper in it...
Will sure try it out!!!
thanks a lot Mr. RenderMan 8)
Share this post
Link to post
jamesfui
:P thanks! i already read the guidelines you posted... now i understand =)
will sure keep in mind on my next post!
thanks ya! 8)
Share this post
Link to post
Lee Mac
wow!!! :shock:
Thanks - I'm flattered that my reputation precedes me. o:) Thanks for using my programs, I hope they can assist you in your work.
A good point to raise, however for clarification, note that the defined symbol in this case is "c:arxload", not the protected arxload symbol :thumbsup:
Share this post
Link to post
BlackBox
You're very welcome :); I too am a student of Lee's so-to-speak. :P
Share this post
Link to post
BlackBox
Cheers, Lee - on both counts! LoL :beer:
Share this post
Link to post
Lee Mac
Well... I think you've long overtaken me with your .NET studies :thumbsup:
Share this post
Link to post
BlackBox
That is kind of you to say, my friend. :oops:
It's funny you mention .NET as I've just written a LispFunction Method "NETLOAD" for LISP that accepts a single argument, a valid file path to DLL, as String (just for fun). :geek: LoL
Share this post
Link to post
BlackBox
FWIW -
I keep both the 32-Bit, and 64-Bit MDITAB .ARX files in the same directory (I just renamed the ones for 64-Bit as noted in the code below), and use this **shell to filter for which one to load across multiple AutoCAD versions, and operating systems:
** I actually do not use this command, rather I use a System Variable Reactor to perform the same function automagically.
[color=black]
[/color](defun c:MdiTab  (/ 64Bit-p)
   ;; © RenderMan, 2011
   (vl-load-com)
   (defun 64Bit-p ()
   ;; Returns T if version is 64-Bit
   ;; Example: (64bit-p)
   (if (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
     T
     nil))
   ((lambda (key sdi / mditab flag)
      (if (and
            sdi
            (setq mditab
                   (cond
                     ((vl-string-search "17" key)                        ; 2007, 2008, 2009
                      (if (64Bit-p)
                        "mditab17x64.arx"
                        "mditab17.arx"))
                     ((vl-string-search "18" key)                        ; 2010, 2011, 2012
                      (if (64Bit-p)
                        "mditab18x64.arx"
                        "mditab18.arx"))))
            (setq flag (findfile mditab))
            (not (vl-position mditab (arx))))
        (and (arxload mditab) (princ "\rMDITAB: LOADED "))
        (cond
          (flag (and (arxunload mditab) (princ "\rMDITAB: UNLOADED ")))
          (mditabs
           (prompt (strcat "\n** \"" mditab "\" cannot be found ** ")))
          (sdi (prompt "\n** This AutoCAD version not supported ** "))
          ((prompt "\n** Command not allowed in SDI mode ** ")))))
     (vlax-product-key)
     (= 0 (getvar 'sdi)))
   (princ))
HTH
Share this post
Link to post
jamesfui
Yep! it sure works alrighty... :lol:
thanks a lot LeeMac!!
be sure to help too on my next post later k ;)
Share this post
Link to post
jamesfui
the second suggestion from RenderMan works fine too! thanks ya ;)
Share this post
Link to post
N_461
Hey boys, not sure how old this thread is, dates not showing up ... BUT I just ran this (32 vs 64 code) and I get the incompatable string in my face?
Im running 2010 Cad, Win7 64
am i not doing something here?
Share this post
Link to post
N_461
**add: just wanting to add into my acaddoc.lsp
Share this post
Link to post
BlackBox
Which code specifically?
Also, if you're able to determine... What line throws the error when you step through in VLIDE?
Share this post
Link to post
