jamesfui Posted December 18, 2011 Posted December 18, 2011 hi.. need help on creating lsp that can: > repeat last 2nd command with right click on other/all opened drawings! example; ``````` different drawings are currently opened; dwg1, dwg2, dwg3, etc.. if i use command 'zoom all' on dwg1 & then 2nd command 'close' the dwg1, now the next dwg2 is current, when i do the right click, it popups the HELP menu instead of the last 2nd command 'zoom all' !? As for the options, i already config with right click repeat last command! So how to make the other opened drawings repeat the last 2nd command with right click when one drawing closes?!? thanks Quote
