wimal Posted December 26, 2011 Posted December 26, 2011 (defun c:TesT (/ sc ss i sn) ;;; Tharwat 13. Dec. 2011 ;;; (if (and (setq sc (getdist "\n Specify Scale factor :")) (setq ss (ssget "_:L" '((0 . "INSERT") (2 . "dot")))) ) (progn (repeat (setq i (sslength ss)) (setq sn (ssname ss (setq i (1- i)))) (command "_.scale" sn "" (cdr (assoc 10 (entget sn))) sc) ) (sssetfirst nil ss) ) (princ) ) (princ) This code is working properly in good drawing but in the bad drawing the dots are moving far away from existing position. Please Help to find out the error. bad.dwg GOOD.dwg Quote
eldon Posted December 26, 2011 Posted December 26, 2011 What would happen if you set the UCS in the bad drawing to World? And your Insert units in the bad drawing are millimetres? Might make a difference Quote
wimal Posted December 27, 2011 Author Posted December 27, 2011 What would happen if you set the UCS in the bad drawing to World? And your Insert units in the bad drawing are millimetres? Might make a difference Thanks Eldon. After setting UCS to World , it working properly. Thanks again. Quote
pBe Posted December 27, 2011 Posted December 27, 2011 No need to change UCS this (cdr (assoc 10 (entget sn))) to this [/color] ([color=blue]trans[/color] (cdr (assoc 10 (entget sn))) [color=blue]0 1[/color]) Quote
