brl2008 Posted December 29, 2011 Posted December 29, 2011 hi folks It been sometime here is the problem that i have. i need to send a drawing out to a clent of our's. it has a XREF with it . so here what i do. open drawing, purge it, go to xref manger highlite the referrence, right click, hit bind, Bind Xref/DGN underlay window comes up check bind hit ok it go thur it stuff. the xref disapear from the drawing but it still shows in the xref manger with a coment on the command line that say : Error : at least one of the specified xref failed to bind for an unknown reason. so what steps am i missing, could be a easy fix. all help is well come thank you for the support brl2008 Quote
tzframpton Posted December 29, 2011 Posted December 29, 2011 Try to use eTransmit instead. That usually always works even when I get errors such as these. 1 Quote
brl2008 Posted December 30, 2011 Author Posted December 30, 2011 thank you StykFacE i tried that eTransmit and followed some step form another thread that cad64 did. so save to my desk top and autocad open, i go to open find file and try to open it and get this message "cannot find the specified drawing file please verify that the file exists." but close autocadd and open file from my desktop and scroll down to the DWG icon double click on it, will open in autocadd as read only. that sound right don't it again thanks for the help brl2008 Quote
RobDraw Posted January 3, 2012 Posted January 3, 2012 Another method would be to insert the drawing as a block. First make sure you have the insertion point of the XREF. Detach it and the insert as a block. Quote
Tiger Posted January 3, 2012 Posted January 3, 2012 I get this error mostly when I have x-refs with Proxy Objects in them, i.e. they have been created by an Autodesk Vertical or Microstation. Once in a while I have succeeded in cleaning the offending x-ref enough so it works to bind it (run audit, purge -purge > R (note the hyphen), delete all unecessary information) but that is very rare. It needs to be done in the X-ref itself though. But the easiest is often to do what Rob suggests, insert it as a block instead. Quote
paul1966 Posted January 3, 2012 Posted January 3, 2012 i had the same problem sometimes too due to proxy objects, however since i downloaded the object enablers from autodesk i have not had the problem, touch wood! Quote
The_SuperVixen Posted January 6, 2012 Posted January 6, 2012 I do the same as mentioned before when I have this problem. Detach the Xref, purge the drawing and insert the xref file as a block. Quote
vdthanh Posted October 20, 2025 Posted October 20, 2025 On 30/12/2011 at 06:21, tzframpton said: Try to use eTransmit instead. That usually always works even when I get errors such as these. wow this works thank u so much Quote
