whenever i'm done editing/saving BLOCK EDITOR then back to the MODEL plan, my cursor vanishes, is this one of Acad 2011 bugs? only re-opening the file will be back to normal.
Do you have all service packs and hotfixes installed? That definitely sounds like a bug to me.
This frequently occurs for me in larger files in 2011/2012 where I have to exit/reopen the drawing to get it back.
no, i don't have and try any, where can i get them, btw?
hmmm, so it occured on Acad 2012 as well
That's a bug of all cad versions and to go back as it was running normally you should close Autocad and open once again .
I just tried on 2012 Vanilla, and did not have that problem.
may i know ur PC spec?
Nothing to write home about, save that I have a 21 1/2" screen, great speakers and a built in TV tuner.
Disappearing cursor has not occured since I upgraded my graphics card and killed InfoCenter. Do you have Hardware Acceleration turned ON?
What do you mean about killing InfoCenter? is that a running background program u killed from TaskManager? i have Nvidia Control Panel, i think it's a kind of Graphic Acceleration, isn't it?
Your graphics card is not recommended or approved. Maybe a different driver will help. Check your processes to see if there are any memory hogs.
Google "Speed up Windows 7" and "Speed up AutoCAD". Kill off info center. Buy a graphics card "Approved and Certified" by Autodesk.
