ixyak Posted January 3, 2012 Share Posted January 3, 2012 whenever i'm done editing/saving BLOCK EDITOR then back to the MODEL plan, my cursor vanishes, is this one of Acad 2011 bugs? only re-opening the file will be back to normal. Quote Link to comment Share on other sites More sharing options...
tzframpton Posted January 3, 2012 Share Posted January 3, 2012 Do you have all service packs and hotfixes installed? That definitely sounds like a bug to me. Quote Link to comment Share on other sites More sharing options...
Organic Posted January 3, 2012 Share Posted January 3, 2012 This frequently occurs for me in larger files in 2011/2012 where I have to exit/reopen the drawing to get it back. Quote Link to comment Share on other sites More sharing options...
ixyak Posted January 3, 2012 Author Share Posted January 3, 2012 Do you have all service packs and hotfixes installed? no, i don't have and try any, where can i get them, btw? This frequently occurs for me in larger files in 2011/2012 hmmm, so it occured on Acad 2012 as well Quote Link to comment Share on other sites More sharing options...
Tharwat Posted January 3, 2012 Share Posted January 3, 2012 That's a bug of all cad versions and to go back as it was running normally you should close Autocad and open once again . Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 3, 2012 Share Posted January 3, 2012 I just tried on 2012 Vanilla, and did not have that problem. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 3, 2012 Share Posted January 3, 2012 That is not a bug in all versions of AutoCAD. Service packs and hot fixes can be downloaded from the AutoDesk website. http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618 Create a RESTORE point before loading any new software. Quote Link to comment Share on other sites More sharing options...
ixyak Posted January 5, 2012 Author Share Posted January 5, 2012 I just tried on 2012 Vanilla, and did not have that problem. may i know ur PC spec? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 6, 2012 Share Posted January 6, 2012 Nothing to write home about, save that I have a 21 1/2" screen, great speakers and a built in TV tuner. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 6, 2012 Share Posted January 6, 2012 Disappearing cursor has not occured since I upgraded my graphics card and killed InfoCenter. Do you have Hardware Acceleration turned ON? Quote Link to comment Share on other sites More sharing options...
ixyak Posted January 10, 2012 Author Share Posted January 10, 2012 Disappearing cursor has not occured since I upgraded my graphics card and killed InfoCenter. Do you have Hardware Acceleration turned ON? What do you mean about killing InfoCenter? is that a running background program u killed from TaskManager? i have Nvidia Control Panel, i think it's a kind of Graphic Acceleration, isn't it? Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 10, 2012 Share Posted January 10, 2012 Re: InfoCenter and how to disable it. http://otb.manusoft.com/2010/11/disable-autocad-infocenter.htm Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 10, 2012 Share Posted January 10, 2012 Your graphics card is not recommended or approved. Maybe a different driver will help. Check your processes to see if there are any memory hogs. Google "Speed up Windows 7" and "Speed up AutoCAD". Kill off info center. Buy a graphics card "Approved and Certified" by Autodesk. Quote Link to comment Share on other sites More sharing options...
