ReMark Posted February 22, 2012 Posted February 22, 2012 Reading this might help you understand the process a little bit better. It discusses how to use a script, a batch file and a lisp routine. Changing Hundreds of AutoCAD Drawings in a Hurry by Dan Abbott, Chris Linder and John Jordon. This was an AutoDesk University 2005 course. http://www.widom-assoc.com/AU-CP12-3L.pdf Quote
Lee Mac Posted February 22, 2012 Posted February 22, 2012 Remark, Just an FYI, that article recommends using a Batch file (.bat) to run the Script (which then calls the LISP) on each drawing in a directory. To my knowledge, this process will unnecessarily reopen the AutoCAD application for every drawing and is hence very slow. I would instead recommend using only a Script to open each drawing, run the LISP, save / close the drawing, then open the next drawing since this will all occur within a single instance of the AutoCAD application, and is consequently much quicker. Lee Quote
Lt Dan's legs Posted February 22, 2012 Posted February 22, 2012 (defun putexcel ( _file _lst flag / _excelapp _ofile _workbooks _ws _tbs _cells ) (if (and (setq _excelapp (vlax-get-or-create-object "Excel.Application")) (setq _workbooks (vlax-get _excelapp "Workbooks")) (or (and (findfile _file) (setq _ofile (vlax-invoke _workbooks "Open" _file)) ) (and (setq _ofile (vlax-invoke _workbooks 'Add)) (vlax-invoke _ofile 'Saveas _file) ) ) ) (progn (vlax-for w (vlax-get _excelapp "Sheets") (setq _tbs (cons w _tbs)) (cond ( (eq (vla-get-name w) _sheet) (setq _ws w) ) ) ) (if (and (or _ws (setq _ws (last _tbs))) (setq _cells (vlax-get _ws 'cells)) ) (foreach x _lst (apply (function vlax-put-property) (append (list _cells 'item) x) ) ) ) (vlax-invoke _ofile 'Save) (if flag (progn (vlax-invoke _ofile 'close) (vlax-release-object _excelapp) )(cons _excelapp _ofile) ) ) ) ) (defun getexcel ( _file _sheet flag / _workbooks _ws _tbs _cc _l ) (if (and (setq _file (findfile _file)) (setq _excelapp (vlax-get-or-create-object "Excel.Application")) (setq _workbooks (vlax-get _excelapp "Workbooks")) (setq _ofile (vlax-invoke-method _workbooks "Open" _file)) ) (progn (vlax-for w (vlax-get _excelapp "Sheets") (setq _tbs (cons w _tbs)) (cond ( (eq (vla-get-name w) _sheet) (setq _ws w) ) ) ) (if (or _ws (setq _ws (last _tbs))) (progn (setq _cc (vlax-get (vlax-get (vlax-get _ws 'UsedRange) 'Columns ) 'Count ) )(setq _n 0) ( (lambda ( / _v _tmpl ) (vlax-for x (vlax-get _ws 'UsedRange) (setq _v (vlax-get x 'value)) (cond ( (not _v)(setq _v "")) ( (numberp _v)(setq _v (rtos _v 2))) )(setq _tmpl (cons _v _tmpl)) (if (<= _cc (setq _n (1+ _n))) (progn (setq _l (cons (reverse _tmpl) _l)) (setq _tmpl nil _n 0) ) ) ) ) ) (and flag (progn (vlax-invoke _ofile 'Close :vlax-false) (vlax-release-object _excelapp) (setq _ofile nil _excelapp nil) ) ) ) ) ) ) (reverse _l) ) _$ (GETEXCEL "C:\\specs.XLS" ;;filename nil ;;sheet (if nil, uses sheet1) t ;;t to close and release excel, nil to leave file & excel open ) ;;returns ;;(("testing a1" "testing b1") ("testing a2" "testing b2")) _$ (putexcel "c:\\specs.xls" ;;filename (list ;; a list of items to put in (list 4 ;; row 4 ;; column "final test" ;;value ) ) nil ;;leave open ) ;; if nil, returns (#<VLA-OBJECT _Application 242ceeb4> . #<VLA-OBJECT _Workbook 135cfd3c>) Quote
ReMark Posted February 22, 2012 Posted February 22, 2012 Thank you Lee Mac and Lt. Dan. Your advice should prove useful to the OP. Consider my input only as a catalyst. Regards. Quote
Lt Dan's legs Posted February 22, 2012 Posted February 22, 2012 I've taken these from other codes I have so somethings may not make sense.. but I'm sure you get the idea. I did this one a while ago for fun (defun c:test ( / *error* cad ap asheet allp sha p1 p2 p3 p4 pt1 pt2 flag gr pt fgr ) (vl-load-com) (defun *error* ( msg ) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (cond ( (and sha (list sha)) (mapcar (function vla-delete) sha) ) ( sha (vla-delete sha) ) )(vlax-release-object ap) (princ) ) (defun cad nil (setq *acad* (cond ( *acad* ) ( (vlax-get-acad-object) ) ) ) ) (defun allp ( pt )(mapcar (function (lambda ( x )(if (minusp x)(- x) x))) pt)) (setq ap (vlax-get-or-create-object "excel.application"))(lib "excel") (if (not (setq asheet (vlax-get ap 'activesheet))) (setq wb (vlax-get ap 'workbooks) wb (vlax-invoke wb 'add) asheet (vlax-get ap 'activesheet) ) ) (vla-put-windowstate ap acmax) (vla-put-windowstate (cad) acMax) (setq w (vla-get-width (cad))) (setq h (vla-get-height (cad))) (vla-put-windowstate (cad) acNorm) (vla-put-width (cad) (* 0.5 w)) (vla-put-height (cad) h) (vla-put-windowtop (cad) 0.) (vla-put-windowleft (cad) (- (* 0.5 w) 2)) (setq w (vla-get-width ap)) (setq h (vla-get-height ap)) (vla-put-windowstate ap acnorm) (vla-put-top ap 0.) (vla-put-left ap 0.) (vla-put-width ap (* 0.5 w)) (vla-put-height ap h) (vla-put-visible ap :vlax-true) (vla-put-visible (cad) :vlax-true) (vla-zoomwindow (cad) (vlax-3d-point (list 0. 0. 0.))(vlax-3d-point (list 500. -450. 0.))) (while (eq 5 (car (setq gr (grread t 12)))) (and (not sha) (prompt "\nSpecify first point: ")) (and sha (mapcar (function vla-delete) sha))(setq sha nil) (setq p1 (allp (polar (cadr gr) (* 0.5 pi) 12.))) (setq p2 (allp (polar (cadr gr) (* 1.5 pi) 12.))) (setq p3 (allp (polar (cadr gr) pi 12.))) (setq p4 (allp (polar (cadr gr) 0 12.))) (setq sha (list (vla-addline (vlax-get asheet 'shapes)(nth 0 p2)(nth 1 p2)(nth 0 p1)(nth 1 p1)) (vla-addline (vlax-get asheet 'shapes)(nth 0 p3)(nth 1 p3)(nth 0 p4)(nth 1 p4)) ) ) )(setq fgr (cadr gr)) (setq gr (allp (cadr gr))) (setq pt1 (nth 0 gr) pt2 (nth 1 gr)) (mapcar (function vla-delete) sha)(setq sha nil) (setq flag 3) (while (eq flag 3)(prompt "\nSpecify next point: ") (while (eq 5 (car (setq gr (grread t 12)))) (and sha (mapcar (function vla-delete) sha))(setq sha nil)(setq pt (allp (cadr gr))) (setq sha (list (vla-addline (vlax-get asheet 'shapes) pt1 pt2 (nth 0 pt) (nth 1 pt) ) (line fgr (cadr gr) "acc" t) ) ) ) (if (eq (setq flag (car gr)) 3) (setq sha nil fgr (cadr gr) gr (allp (cadr gr)) pt1 (nth 0 gr) pt2 (nth 1 gr) )(and sha (mapcar 'vla-addline sha)) ) )(vlax-release-object ap)(princ) ) Quote
Mobain Posted February 22, 2012 Posted February 22, 2012 thanks to all you guys for all the help. I have a lot of studying to do to figure out how this all works. I dont seem to know what I'm doing, by the time i figure it out it would probably be quicker to just run the lisp routine on each drawing manually, at least I get payed by the hour Quote
odyseus8 Posted April 8, 2015 Posted April 8, 2015 Sorry to bring out an old topic but I have some questions regarding text extraction from autocad to excel. I'm a newbie too and want a lisp to run for multiple dwg files in a folder. I assume that i should use a batch program like scriptpro but couldn't figure out how to apply a lisp in a script. Also if the name of the file is converted too it would be great. Can anyone help me regarding this topic Thanks in advance Quote
