Brick_top
Set getstring variable using a DCL input box?
Brick_top
Hi i'm new to dcl and would like to know how can I set a getstring variable using a DCL input box.
I thought it would be easy but I haven't figured it out.
thanks
Share this post
Link to post
pBe
edit_box
An edit box is a field that enables the user to enter or edit a single line of text. An optional label can appear to the left of the box. If the entered text is longer than the length of the edit box, the edit box scrolls horizontally.
Share this post
Link to post
Brick_top
Hi there I searched edit_box
It seems it limits the input text to 132 characters. Anyway to avoid that?
Share this post
Link to post
pBe
Really? I never noticed that.
Can you post your code here for us to looked at? Maybe we can suggest a different approach.
Share this post
Link to post
Brick_top
I just copied a tutorial from a web page and was trying to adapt it to my code.
here is the dcl part
SAMPLE2 : dialog {
         label = "Pesquisa de Projetos";
         : column {
           : boxed_column {
             : edit_box {
               key = "username";
               label = "Informação a pesquisar:";
               edit_width = 50;
               value = "";
               initial_focus = true;
//              : edit_box {
//                key = "userage";
//                label = "Enter your Age:";
//                edit_width = 15;
//                value = "";
           : boxed_row {
             : button {
               key = "accept";
               label = " Ok ";
               is_default = true;
             : button {
               key = "cancel";
               label = " Cancel ";
               is_default = false;
               is_cancel = true;
here is the lisp part
(defun saveVars()
 (setq userName(get_tile "username"))
 ;(setq userAge(atoi(get_tile "userage")))
(defun C:SAMPLE2()
 ;;;--- Load the dcl file
 (setq dcl_id (load_dialog "SAMPLE2.dcl"))
 ;;;--- Load the dialog definition if it is not already loaded
 (if (not (new_dialog "SAMPLE2" dcl_id))
    (alert "The SAMPLE2.DCL file could not be loaded!")
     (exit)
 ;;;--- If an action event occurs, do this function
 (action_tile "accept" "(setq ddiag 2)(saveVars)(done_dialog)")
 (action_tile "cancel" "(setq ddiag 1)(done_dialog)")
 ;;;--- Display the dialog box
 (start_dialog)
 ;;;--- Unload the dialog box
 (unload_dialog dcl_id)
 ;;;--- If the user pressed the Cancel button
 (if(= ddiag 1)
   (princ "\n Sample2 cancelled!")
 ;;;--- If the user pressed the Okay button
 (if(= ddiag 2)
     (princ "\n The user pressed Okay!")
 ;;;--- Suppress the last echo for a clean exit
I can post my code but it is very specific to a drawing file, don't know if that helps.
Anyway in both this code and in this example. The resulting string length is 132 characters.
Share this post
Link to post
Brick_top
Nice... I can' set a limit with
edit_limit = (number);
withouth "()"
Share this post
Link to post
Brick_top
I tried it with
edit_limit = 512;
and it works fine :)
Share this post
Link to post
Brick_top
But now there is something that bothers me.
Anyway I could increase the edit box size so that all of the characters were visible while i type?
Share this post
Link to post
Lee Mac
Use edit_width
Share this post
Link to post
Brick_top
sorry for not being clear, but as it seems it only scrools horizontally?
I would like it to scrool vertically?
sorry if my english sounds weird.. I don't know if all the words I write exist
Share this post
Link to post
Lee Mac
Not possible using a standard DCL edit_box - you can change the height, but the text will not move onto the next line. Unfortunately standard DCL doesn't offer a "text_area" tile, the closest you can get (in appearance) is a list_box, but this of course cannot accept text input.
Share this post
Link to post
Brick_top
ok, thanks a lot for your info.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
