toygoose Posted January 8, 2012 Author Posted January 8, 2012 When I run the QuickDraw command on a solid it stops here Quote
toygoose Posted January 8, 2012 Author Posted January 8, 2012 I did read your post. Please read mine, I stated that my auth code keeps changing take a closer look at the images. I was wondering if yours changes aswell? Each time I try to use any of the commands I get a this window that auth code window pop up and the codes are diff. This window should not come up after the install. Does your pop up come up for each diff command? Quote
ReMark Posted January 8, 2012 Posted January 8, 2012 I did not pay attention to the authorization code because it is grayed out. Whether or not it changes with each occurrence is of no real concern to me. And the answer is "no". The pop up box does not come up with each different command. I don't know why AutoSolids works differently for me than it does for you. Your friends have it working? Then "borrow" their authorization code. It shouldn't matter now that the company has virtually given the program away. Quote
toygoose Posted January 9, 2012 Author Posted January 9, 2012 I understand you have this installed now. Would you try to run the QuickDraw command on a solid? Quote
ReMark Posted January 9, 2012 Posted January 9, 2012 Not at the moment. The program is installed on a remote CAD computer. I'm currently not at that location. Quote
toygoose Posted January 9, 2012 Author Posted January 9, 2012 No worries, I just got it working!!!!!!!!!!!!!! ZIP files and emails can be funny sometimes I guess. I had the guy reemail the files and it looks like the ini. file on the old email was jumbled up.... Quote
xiaxiang Posted November 22, 2012 Posted November 22, 2012 So what do you want to know about AutoSolids other than the fact that the company that produced it went out of business? Download free AutoSolids stuff here.... http://www.autosolids.com/downloads.htm ok, dear Remark http://www.autosolids.com/downloads.htm this link is broken now If you ever download autosolids_v5.12_setup files, please, please upload here My file was destroyed by virus Quote
ReMark Posted November 22, 2012 Posted November 22, 2012 I'll have to look and see if I kept the files. It's been so long since I used the program I forget which computer (I have access to three) I downloaded the files on. Update. I found a file called AutoSolids 2007.msi but I am not going to upload it here. You'll have to PM me with your email address so I can send it to you. Quote
xiaxiang Posted November 22, 2012 Posted November 22, 2012 (edited) I'll have to look and see if I kept the files. It's been so long since I used the program I forget which computer (I have access to three) I downloaded the files on. Update. I found a file called AutoSolids 2007.msi but I am not going to upload it here. You'll have to PM me with your email address so I can send it to you. woh...thanks a lot! my email address has been sent to you. Edited November 23, 2012 by xiaxiang Quote
ReMark Posted November 23, 2012 Posted November 23, 2012 Please remove your email address from the above post. I sent you an email this morning (Friday). Quote
xiaxiang Posted November 26, 2012 Posted November 26, 2012 Please remove your email address from the above post. I sent you an email this morning (Friday). Thanks Mark and apologize for late reply. I've find this program all over the world,until finally you sent me here. Thanks! Quote
zaphod Posted March 28, 2014 Posted March 28, 2014 I realize this is an old thread, anyone have a working link for AutoSolids 2007? Thanks, Zaphod Quote
ReMark Posted March 28, 2014 Posted March 28, 2014 Your search did not turn up anything? I'm pretty sure I have the AutoSolids 2007.msi file. Quote
ReMark Posted March 28, 2014 Posted March 28, 2014 I do have the .msi file if that's what you are looking for. Quote
zaphod Posted March 28, 2014 Posted March 28, 2014 yes please, how do I PM on this forum, or am I too new? Quote
ReMark Posted March 28, 2014 Posted March 28, 2014 You may be too new. Put your email address in your next post. Like this: m y e m a i l a d d r e s s AT g m a i l DOT c o m. That way a bot won't harvest it. Once I have it jotted down I'll let you know. You can then edit the post and remove it. Sound like a plan? Quote
zaphod Posted March 28, 2014 Posted March 28, 2014 sounds good I need to start looking around this site daily, lot of good info Quote
ReMark Posted March 28, 2014 Posted March 28, 2014 OK I have it. Unfortunately a client just showed up so it will be a few minutes. Thanks. Quote
