Change instances of Block A to Block B
I'm sure I've seen it here before and have probaly forgotten how to do something that is simple although how do I change an inserted block (A) into block B? i.e. if I select 1000 instances of Block_A I want them to all be converted into Block_B (without editing Block_A) where Block_b is already defined in the CAD file. :)
Edit: Doh! with regards to the typo in the title :P
Edited by Organic
BLOCKREPLACE should do the trick....
