What is actually surface modelling when using Inventor 2012. Is It like
using 3Ds max or Inventor Alias design?
Yes and no.
You're creating something which is substantially similar to the NURBs that you use in Max, but they have a completely different function. A surface in Inventor is used as a tool to help create an object. A surface in Max (and most other similar 3D software - Maya, Lightwave, etc.) is the object. Also, you can't edit a surface in Inventor by dragging points and polys around. You have to edit the geometry used to create the surface instead.
There are several surface modeling tutorials in my signature.
(most of them are a little old - but the Vacuum tutorial is fairly up-to-date)
With Inventor 2012 you will also want to investigate the Edit Form (Alias Edit) link to Inventor Fusion.
There are several classes here http://au.autodesk.com - see presentor Kevin Schneider.
