TLRstacker Posted January 12, 2012 Posted January 12, 2012 i am new to using tweaks so i assume this is something i am doing wrong, but it is very frustrating! i have made an ipn of a reasonably simple assembly and would like to move a locking pin out and slide the part it is locking up then slide the locking pin back in. i can get the locking pin out and the other part up but when i try and tweak the locking pin back in it edits the existing tweak and then deletes it (i assume because the value is back to 0. any ideas how ti fix this? i have tried to create the tweak with a couple of other components in it and then delete the components out that i don't want tweaked, but when i delete the unwanted components from the tweak it throws some of the other components out of position. thanks in advance for any help. Quote
JD Mather Posted January 12, 2012 Posted January 12, 2012 Is there a reason you need to do this in ipn rather than Inventor Studio? Can you attach the assembly here? Quote
