(setq bt (substr text 1 1))        ;CHECKING first letter
I am checking the Fist letter or number of "text"
How can I identify weather variable bt is a number or letter.
(wcmatch) is your friend here
(wcmatch bt "#")
Should return T if bt 'Matches any single numeric digit' . David
. David
Thanks for your help .I can continue now.
You could check without using substr to retrieve the first letter using:
(wcmatch text "#*")
Will return T if the string 'text' begins with a number.
(wcmatch text "#*")
Thanks Lee
