cadman6735 Posted January 16, 2012 Posted January 16, 2012 I am trying to create a dynamic block with two attributes, a double grid head, when I add a stretch parameter to the head it only affects the first assigned attribute. I have added a stretch parameter to each attribute and only the firt attribute will move. What are the rules with attributes in dynamic blocks, the only thing I found in the help was I have to lock posistion for attributes to be affected by the paramter assigned by the dynamic block. I have seen and followed many tutorials but all only deal with one attribute. Thanks Quote
cadman6735 Posted January 16, 2012 Author Posted January 16, 2012 found the answer in the similar threads, shame I have to post to get a better search result in similar threads than I can find from the search itself... I am sure I am not useing the search right but... http://www.cadtutor.net/forum/showthread.php?20102-Attributes-inside-Dynamic-Blocks!!-Help!!/page2 Quote
AlxLicorne Posted January 26, 2012 Posted January 26, 2012 What about in the block editor, 'ctrl a' + 'ctrl c' open a new block, 'ctrl v', save as new name. go back to model space, insert your new block... explode or burst, done ! Quote
