Brick_top Posted January 16, 2012 Posted January 16, 2012 ok I have a routine that its doing something I can't get I have it set to load with every drawing. but when I run it, after the first dialog box it prompts me this error ; error: bad argument type: (or stringp symbolp): nil the routine will start working as I want it if I open it in VLIDE and choose "Load text in editor" Why is this? Quote
Brick_top Posted January 16, 2012 Author Posted January 16, 2012 I already went here: http://lee-mac.com/errormessages.html but I can't make the vlisp to point me to the error. Quote
Lee Mac Posted January 16, 2012 Posted January 16, 2012 Follow this to determine the source of the error: http://lee-mac.com/debugvlide.html Quote
Brick_top Posted January 17, 2012 Author Posted January 17, 2012 Hi lee I followed your tutorial some time ago and I did try that, but the vlide doesn't point me to the error when I select "last break source" it only shows a dialog box with the error I posted in the first post. Truth be said I didn't follow the "watching variables" part. I will do that now. Quote
Brick_top Posted January 17, 2012 Author Posted January 17, 2012 Well this is weird for me. I removed the routine from the startup suite and added it again, and now it is working edit - by the way I'm sure it was the same routine Quote
Brick_top Posted January 24, 2012 Author Posted January 24, 2012 This is happening again now in two routines, they will only work as I want them when I load them with "load text in editor". The editor doesn't point me to the error but I check some variables which should be set with the dcl and they are nil. Quote
BlackBox Posted January 24, 2012 Posted January 24, 2012 More information is needed; consider posting your code to allow us to better assist you. Quote
Brick_top Posted January 24, 2012 Author Posted January 24, 2012 well this is very specific to a file: You would have to change the directories I have in the lisp file with ones to test. after that you need to open the Lista.dwg file I attached load the lisp and type "proc" to start. than in the dialog box you can put for example "pacheco" if everything goes well a new dialog box should appear with search results, otherwise it just gives an error. Sorry about the messy code. Lista.dwg proc.lsp proc.dcl Quote
Brick_top Posted January 25, 2012 Author Posted January 25, 2012 commented out a part and changed the name to a function, don't know why but now it works. thanks Quote
