Help, the lineweights are fine when on the "preview" setting, but when printing them to PDF some appear extremely thick while other ones appear fine.
What do I do??
hmm... not sure it could be many things, 2 that come to mind to check are the lineweights of the heavy printed objects and the pen assignments in the plot style table editor..
yeah i already did all that, i mean the text that comes out thick and the text that comes out thin and the way it's supposed to are on the same layer...and therefore the printing properties are the same...which is what doesn't make sense...
are they the same color also ? the pen settings are by color usually, or that's the way I have it set up...
what version of acrobat reder/ pdf you are using? in acrobat 5.0 expect to be your line to be on a default lineweigth, try using adobe acrobat 6.0.
yeah, the colors are exactly the same, it's on the SAME LAYER :cry:
as to adobe, i have the latest version.
we are using acrobat 6.0 and print it on .pdf(monochrome) and it goes out just the same, since one of our office pc is installed with acrobat 5.0, all the lineweight and text goes funky, try setting the option of your acrobat(latest version) or use acrobat 6.0
one more... try setting up the lineweight on the cad. try to separate layers on each purpose, seldom use DEFAULT lineweight on layers ok.
does it print out on paper ok from acrobat?..i suspect it will as acrobat sometimes has a problem displaying it on screen correctly but it will print fine...
  • 2 weeks later...
I am having this same trouble, and i have tried all the same! When you print from the PDF, it still shows the thick lineweights!
Try printing as an image from the advanced options.
