wesley Posted January 18, 2012 Posted January 18, 2012 2010 version in model space scale 1:1, set text height but appears much smaller than rest of drawing Quote
Dadgad Posted January 18, 2012 Posted January 18, 2012 Sounds like you are creating text or dimensioning in modelspace? If you zoom in the text height seems appropriate, right? Unless you are using annotative text or dimensions, I would suggest putting those elements and your drawing sheet in paperspace. Quote
ReMark Posted January 18, 2012 Posted January 18, 2012 Will you be utilizing a paper space layout? Yes/No/What is a layout? Do you know what annotative scaling is and how it can be applied to text? Yes/No? Quote
Tiger Posted January 18, 2012 Posted January 18, 2012 Probably your text is set to Annotative - highlight the text, bring up Propterties-palette (PR for short) and change Annotative to No. Quote
wesley Posted January 18, 2012 Author Posted January 18, 2012 Thank you very much Tiger - I will try it out and let you know Quote
wesley Posted January 18, 2012 Author Posted January 18, 2012 I would have to zoom in so far that I would lose the surrounding drawing. I will focus on use of annotative text and see if it solves the issue. Thanks Dadgad Quote
wesley Posted January 18, 2012 Author Posted January 18, 2012 I can't say that I know what annotative scaling is but I will focus on that and see if I can solve the issue. Thanks ReMark Quote
