jquackenbush Posted January 19, 2012 Posted January 19, 2012 I have a block of a survey from an outside company which was sent as a block. I am guessing that when it was creating, they un-checked the box that allows it to be exploded. I would like to edit the block, and without being able to explode it, I have to go into the block editor to do so. Is there a way in block manager to change it so that I can explode the block? Quote
RobDraw Posted January 19, 2012 Posted January 19, 2012 Yes. While in the block editor, look in the properties box for a selection to allow exploding. Quote
JBullseye74 Posted January 19, 2012 Posted January 19, 2012 also you could just refedit might be a bit quicker Quote
Organic Posted January 19, 2012 Posted January 19, 2012 Type 'b' as if you were going to create a new block. In the drop down list at the top of the new block window that pops up, select the existing block containing the survey data. You can then untick the not allow exploding box. It will ask you to redefine the block, click yes. Quote
Bernie Posted May 2, 2012 Posted May 2, 2012 Type 'b' as if you were going to create a new block. In the drop down list at the top of the new block window that pops up, select the existing block containing the survey data. You can then untick the not allow exploding box. It will ask you to redefine the block, click yes. Hi Dink87522, that is a helpfull tip. it works faster than the Beditor. But do you know of a way to retrieve this "allow exploding" (and "scale uniformly") information from the block through lisp? ... so I can change it to my own preference? For that would really me 'happy'. [i would - by default - reset all these blocks to 1 standard. Quote
