therring Posted January 20, 2012 Posted January 20, 2012 I have used image transparency successfully in the past . However, now I'm having to result to clipping to get rid of the white background within the frame. I have no results with jpg, gif, tiff, bmp, etc. Is there a setting that may prevent the transparency from functioning? Please help! Quote
profcad Posted January 20, 2012 Posted January 20, 2012 Color images must have a transparency layer. If the image doesn't have a transparency layer then one must be added by using a program like photoshop. If it's a black and white image, then the white background should be transparent when the image transparency is turned on. Quote
