blackeagle1245 Posted January 21, 2012 Posted January 21, 2012 I'm very new to navisworks. I export my mep drawings to navisworks and now I can walk with third person. But how can I put him to zero coordinate of Z axe?. I can move by pan but dont know exactly how can I make Z coordinate constant?. And just wonder how tall is the third person ? Quote
Dadgad Posted January 21, 2012 Posted January 21, 2012 Do you have gravity turned on? If you do, his gravity will hold him in place, or rather keep him from floating away. If you put him on a deck or other flat surface, if you pass the edge he will fall off. Do you have crouch and collision turned on? I haven't used it much, nor in some time, but as I recall you can also adjust the height of the avatar. Quote
blackeagle1245 Posted January 21, 2012 Author Posted January 21, 2012 I dont know where can I adjust the height?. Which one should I activate?. What does each one of them do?. Quote
