Dadgad Posted January 25, 2012 Share Posted January 25, 2012 Dadgad: In other words you don't have a graphics card you have an onboard graphics chip? I am woefully illiterate when it comes to graphics cards/chips if you will. Looking to upgrade, I am going to ditch VISTA Home Premium for Windows 7 Ultimate, assuming that my 32bit system is up to the task. Here are the specs on my workhorse, as it stands now. Any thoughts or suggestions? Quadro is seriously expensive hereabouts, probably go with GeForce as they seem to be most available here. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 25, 2012 Share Posted January 25, 2012 So we are upgrading a laptop? Well, save your money and go with Win7 Home Premium (although I usually suggest Pro as the preferred OS). Can you actually install a dedicated graphics card in your laptop? What is the max amount of RAM you can install in your computer? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted January 25, 2012 Share Posted January 25, 2012 The old warhorse deserves a new set of shoes. The Vista drives me nuts, Windows 7 Home Premium on the Dell is so much better. Disregarding price, which would you choose, Pro or Ultimate? When I said woefully illiterate, perhaps I was overstating my credentials. I had assumed (perhaps wrongly?) that I could. Seems like I should go about this from the other direction, eh? The HP I have is the non-Penryn one. Busy now, but need to look into it when time permits, I'll get all the relevant specs. Quote Link to comment Share on other sites More sharing options...
ReMark Posted January 25, 2012 Share Posted January 25, 2012 I went with Win7 Ultimate on my home system. My work system uses Win7 Pro. Pro is fine. Once you look into it come back here and start a new thread. Bring your full specs with you too. Slacking off is not permitted. I have eyes everywhere (my ghost crabs are watching you). Quote Link to comment Share on other sites More sharing options...
miroslav_s Posted January 25, 2012 Author Share Posted January 25, 2012 My apologizesfor not answering to your question earlier. Been busy. Yes, I did use (or should I saytested the command “constrains parallel” but when you asked me in one of yourposts my brain was blocked I guess and I forgot what it was. Silly me! Also, Isaw the mistakes I made with the fence and you are right putting titleblock onits own layer. Will correct that as well. Thanks once again for everything Bestregards Miro Quote Link to comment Share on other sites More sharing options...
khama Posted February 19, 2012 Share Posted February 19, 2012 Why not just stretch them to the given point using point filters? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 19, 2012 Share Posted February 19, 2012 And which command(s) would you be using? Quote Link to comment Share on other sites More sharing options...
nestly Posted February 19, 2012 Share Posted February 19, 2012 And which command(s) would you be using? Stretch via grips. Blue grip if it's the top face of an extrusion, red subobject grip if not (Ctrl+Click) Quote Link to comment Share on other sites More sharing options...
khama Posted February 20, 2012 Share Posted February 20, 2012 Thanks nestly. Stretch command is the answer. Point filters constrain the move along the given axis. you can stretch both of them at the same time, one move. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 20, 2012 Share Posted February 20, 2012 Thanks nestly. Stretch command is the answer Can you expand on that. I am unable to use the STRETCH command to "stretch" solids... it just moves them. Quote Link to comment Share on other sites More sharing options...
khama Posted February 21, 2012 Share Posted February 21, 2012 OOPS Sorry I forget that I am using Prosteel and not true 3D solids. Everything is dynamic in Prosteel. You can copy them and move them to the given point using .Z point filter and then union them. That will work. You can stretch them one by one also to the given point using point filters using the arrow grip. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 21, 2012 Share Posted February 21, 2012 So we're now saying that a solid cannot be stretched via its grips is that correct? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 21, 2012 Share Posted February 21, 2012 OOPS Sorry I forget that I am using Prosteel and not true 3D solids. Do a List on one of the objects. Does it return Body rathe than Solid? If you really needed to you could convert Body to Solid in Fusion. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 21, 2012 Share Posted February 21, 2012 I'm not sure what anyone else is saying, but I'm saying grips can be used to stretch multiple faces as one operation. Quote Link to comment Share on other sites More sharing options...
khama Posted February 21, 2012 Share Posted February 21, 2012 Do a List on one of the objects.Does it return Body rathe than Solid? If you really needed to you could convert Body to Solid in Fusion. It is Prosteel and makes it own solids called KS_PLATE and is FULLY dynamic. You can stretch 100 objects of various lengths by selecting all the grips to be moved all in ONE MOVE. It is so much faster and more intuitive than CAD solids. What takes me an hour to do in Autocad can take just 15 mins in Prosteel. Structural steel and plate items are a snap and totally dynamic. I Love it !! As far as productivity goes it is the BOMB !! Quote Link to comment Share on other sites More sharing options...
khama Posted February 21, 2012 Share Posted February 21, 2012 So we're now saying that a solid cannot be stretched via its grips is that correct? No that is not what I am saying. You CAN totally stretch solids one at a time in the direction of extrusion, but if you don't constrain the stretch it will go weird. Point filters are essential. Well I can using the the blue arrow and that is in Acad 2008 and above. Quote Link to comment Share on other sites More sharing options...
khama Posted February 21, 2012 Share Posted February 21, 2012 I'm not sure what anyone else is saying, but I'm saying grips can be used to stretch multiple faces as one operation. Nestly we are not worthy... What a legend.. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 21, 2012 Share Posted February 21, 2012 (edited) You can stretch 100 objects of various lengths by selecting all the grips to be moved all in ONE MOVE. I'm sure ProSteel has advantages, and I may have a look myself as I do quite a bit of steel design, but what you described doesn't sound that much different than regular AutoCAD [video=youtube;jTjao-fdGX4] Edited February 21, 2012 by nestly Quote Link to comment Share on other sites More sharing options...
JD Mather Posted February 21, 2012 Share Posted February 21, 2012 It is Prosteel and makes it own solids called KS_PLATE and is FULLY dynamic. You didn't follow my instructions. If you run the List command on one of the Prosteel objects what does AutoCAD return as the object type? (I am not interested in what Prosteel calls it.) Quote Link to comment Share on other sites More sharing options...
khama Posted February 22, 2012 Share Posted February 22, 2012 I DID answer the question here is the list as requested. It calls it KS_PLATE. Command: Command: list 1 found KS_PLATE Layer: "PS_PLATE" Space: Model space Handle = 1814 Coordinates of Object Entity Coordinate System Origin X=13153.8883 Y=726434.4355 Z= 0.0000 Xaxis X= 1.0000 Y= 0.0000 Z= 0.0000 Yaxis X= 0.0000 Y= 1.0000 Z= 0.0000 VersionIndex = 0 Name of Part = PL 1380x10 PartOrigin =-1 Familyclass =004 Coordinates of used Polygon for this Plate Vertex=0 X= -690.2212 Y= -855.5694 B= 0.0000 Vertex=1 X= 690.2212 Y= -855.5694 B= 0.0000 Vertex=2 X= 690.2212 Y= 855.5694 B= 0.0000 Vertex=3 X= -690.2212 Y= 855.5694 B= 0.0000 Vertex=4 X= -690.2212 Y= -855.5694 B= 0.0000 Quote Link to comment Share on other sites More sharing options...
