jquackenbush Posted January 24, 2012 Posted January 24, 2012 I am cleaing up a drawing from another company, (changing linetypes, text, layers, blocks). When i change blocks, opening the block that I want and saving it as the one that is there, the block comes in at a scale that is a lot larger then what i would like. After saving the new block, if i insert it in, it comes in at the proper scale. Both the drawing and the blocks are at unitless. Any help? Quote
SLW210 Posted January 24, 2012 Posted January 24, 2012 What is the scale of the block that is already in the drawing? (HINT:Check the Properties>Geometry>Scale) Quote
rkent Posted January 24, 2012 Posted January 24, 2012 Are you saving it as an annotative block? What is the annotative scale set to? Quote
