Openantics Posted January 25, 2012 Posted January 25, 2012 if i try and to open a new file or save as a current file, the windows box does not open. the command line does populate asking for file name, etc, but obviously is very tedious to navigate windows folders with a command line! any obvious changes that would prevent windows folder dialogue box not to open?? Quote
ReMark Posted January 25, 2012 Posted January 25, 2012 At the command line type FILEDIA then press ENTER. Change the value from "0" to "1". That should fix the problem. Quote
Openantics Posted January 25, 2012 Author Posted January 25, 2012 Very nice, thank you. What is the advantage to suppressing display of file navigation dialog boxes? Quote
BlackBox Posted January 25, 2012 Posted January 25, 2012 What is the advantage to suppressing display of file navigation dialog boxes? Custom LISP routines, etc. Quote
