jgbgod Posted January 25, 2012 Posted January 25, 2012 I'm stumped. I used the command qselect to select all mtext in model space. I then went to the properties menue and changed all mtext to 1" height. I've got five pages, each with a different viewport. Each viewport is the same scale as the previous one however the text size is not. Mtext was created under the same style. Any ideas? Trying to get this sent to the boss today. Quote
SLW210 Posted January 25, 2012 Posted January 25, 2012 Is the mtext in Model Space? Can you post your file? Quote
jgbgod Posted January 25, 2012 Author Posted January 25, 2012 Thanks for the help. I was able to determine the problem. Scale of the first viewport was not the same as the others. Quote
