CaveMan
Draw Arc on UCS
CaveMan
Good Day
How does one program to draw an arc(Point, Radius, Angle, Angle)
The arc keeps getting drawn according to the WCS? The angles Relate also to the WCS. If a line gets drawn from two Point3D - no problem about the ucs - but arcs and circles retain to WCS even if the user has changed to a UCS?
Aye Help needed here
Even if just a simple example to draw an arc on current user UCS will be Great
Cheers
CaveMan
Share this post
Link to post
BlackBox
These links may be of use:
AutoCAD .NET Developers Guide, here's a snippet:
Create an Arc object
This example creates an arc in Model space with a center point of (6.25,9.125,0), a radius of6, start angle of 1.117 (64 degrees), and an end angle of 3.5605 (204 degrees).
VB.NET
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Namespace FOO
   Class Foo
       <CommandMethod("AddArc")> _
       Public Sub AddArc()
           '' Get the current document and database
           Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
           Dim acCurDb As Database = acDoc.Database
           '' Start a transaction
           Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
               '' Open the Block table for read
               Dim acBlkTbl As BlockTable
               acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
               '' Open the Block table record Model space for write
               Dim acBlkTblRec As BlockTableRecord
               acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), _
                                               OpenMode.ForWrite)
               '' Create an arc that is at 6.25,9.125 with a radius of 6, and
               '' starts at 64 degrees and ends at 204 degrees
               Dim acArc As Arc = New Arc(New Point3d(6.25, 9.125, 0), _
                                          6, 1.117, 3.5605)
               acArc.SetDatabaseDefaults()
               '' Add the new object to the block table record and the transaction
               acBlkTblRec.AppendEntity(acArc)
               acTrans.AddNewlyCreatedDBObject(acArc, True)
               '' Save the new object to the database
               acTrans.Commit()
           End Using
       End Sub
   End Class
End Namespace
Convert Angle from UCS to WCS
Calculating the Angle Between UCS and WCS
HTH
Share this post
Link to post
CaveMan
Cheers Thanks for the source code supplied
Will review it when i have a chance
Below is the two public modules i created - which also works.
Highlited in red was my mistake - Arc was not transformed to current ucs.
______________________________________________________________________
Code:
PublicModule ModDrawArc
FriendFunction DrawArc(ByVal startPoint As Point3d, ByVal Radius AsDouble, ByVal StartAngle AsDouble, ByVal EndAngle AsDouble) As Arc
acDoc.LockDocument()
acBlkTblRec = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim acArc As Arc = New Arc(startPoint, Radius, StartAngle, EndAngle)
[color=red]acArc.TransformBy(GetUcsMatrix(acCurDb))[/color]
acTrans.Commit()
[size=2][size=2][color=black]End[/color][/size][/size][size=2][size=2][color=black]Using[/color][/size]
[/size][color=black][size=2][size=2]End[/size][/size][size=2][size=2]Function[/size][/size][/color]
[size=2][color=#0000ff][size=2][color=#0000ff]_____________________________________________________________[/color][/size][/color][/size]
[color=black] [/color]
[color=black][size=2][size=2]Friend[/size][/size][size=2][size=2]Function[/size][/size][size=2] GetUcsMatrix([/size][size=2][size=2]ByVal[/size][/size][size=2] db [/size][size=2][size=2]As[/size][/size][size=2] Database) [/size][size=2][size=2]As[/size][/size][size=2] Matrix3d[/size][/color]
[color=black][size=2][size=2]Dim[/size][/size][size=2] origin [/size][size=2][size=2]As[/size][/size][size=2] Point3d = db.Ucsorg[/size][/color]
[color=black][size=2][size=2]Dim[/size][/size][size=2] xAxis [/size][size=2][size=2]As[/size][/size][size=2] Vector3d = db.Ucsxdir[/size][/color]
[color=black][size=2][size=2]Dim[/size][/size][size=2] yAxis [/size][size=2][size=2]As[/size][/size][size=2] Vector3d = db.Ucsydir[/size][/color]
[color=black][size=2][size=2]Dim[/size][/size][size=2] zAxis [/size][size=2][size=2]As[/size][/size][size=2] Vector3d = xAxis.CrossProduct(yAxis)[/size][/color]
[color=black][size=2][size=2]Return[/size][/size][size=2] Matrix3d.AlignCoordinateSystem(Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, _[/size][/color]
[size=2][color=black]Vector3d.ZAxis, origin, xAxis, yAxis, zAxis)[/color][/size]
Appreciate
Cheers
CaveMan
Edited by CaveMan
Share this post
Link to post
