You have proxy in dwg that acad can't reperesent and instead that entity acad show box.
Solution
erase proxy or instal enablers for that entity
  • 1 year later...
  • Replies 21
  • JJuarez
    8
  • resullins
    6
  • cios106
    3
  • Jack_O'neill
    2
Posted Images
I realize the original post was a long time ago, but the problem is still an issue almost 2 years later, so here is the solution to the problem....
Type "XCLIP" at the command line,
Select all the block frames,
Hit "ENTER",
Select "DELETE".
This removes the frames leaving the original blocks intact.
Have a great day!!
