viewport
Jadgpanther
remark
mview all good,
when i return to paper space, the viewport has zoomed to extents
tried the variable UCSFOLLOW, still no joy ?
Were you in the new viewport when you issued the UCSFOLLOW command? Also, use Ctrl+R to move between viewports once one is active, this is helpful when you have one viewport over another.
remark
yep, that did not work either,
i read something about using wipeout, and some sequence of commands..
viewports inside viewports - 3 methods
1) First draw a rectangle that will be the size wanted for the big
viewport. Use the Region command and make that a region, now use the
Mview command, Object option and pick the region. Adjust the view in
that viewport accordingly.
Now draw circles or polygons, etc. that will represent the smaller
viewport(s). Place those where you will want them. Use the Region
command again. Use the subtract command and pick the large region
then the smaller one(s). Now draw the circles again in the blank
space, use the Mview command, Object option. Adjust those viewports
accordingly. Because these are regions now you won't be able to edit
them like a normal viewport, IE: grip stretch, etc.
2) In MS use wipeout to hide the area you want another VP to reside.
Now in PS use MVIEW and grab the opposite corners of the wipeout.
Pan and zoom in the new viewport accordingly.
3) In PS you can draw a continuous pline with a large rectangle and
then move into the center and draw a smaller rectangle, all in the
same pline command. You will have two plines one of top of the other
going to the smaller rectangle but that is ok because it won't show.
Nowuse the MVIEW command and use Object option. Now use MVIEW again to
define the smaller viewport grabbing the opposite corners of the small
rectangle. Or after drawing the closed pline, create an mview, then
use theCLIP command and pick on the viewport and then the closed pline.
